been playing around with some different wheel's and have tried vette and Camaro wheels as well as some torque thrust in the past. Still have to install the lowering springs to finish the look as well as decide on my brakes, but I think these actually look good. This is just a weekend car being built for the street. Not going to the track with these wheels. What's opinions on this look??
Had to find special lug nuts due to stud sizes on adapters and hole size on cts wheels and the current lugs are temporary ones till I do the permanent brake setup and the studs stick thru lugs and are discolored so I just put these caps on to hide them. Using the Cadillac wheels is definitely requiring me to change stud sizes and making the brake setup a little more complicated.
I see this post is a little old, but I am curious what the outcome with the CTS-V wheels was. I have an opportunity to get aftermarket rims that were on a CTS-V(same size and backspacing as original) for cheap and am trying to find out how they fit. What wheel spacers did you use and how was fitment?
