I've got a 1985 IROC and the other day I pulled all the wheels off just to clean and polish. Then I noticed a small (1/4 inch) wheel spacer on both sides of the rear axle. Is this a factory thing or did someone along the way decide they wanted a different offset in the rear?
dagwood
close
- Join DateOct 2002
- LocationIn the paint booth!
- iTrader Positive Feedback100
- iTrader Feedback Score(5)
- Car1986 Camaro Drag Car
- Engine383 on Ethanol
- TransmissionAutomatic
- Axle/Gears4.86 Currie 9 inch
- Liked:1,267 Times in 696 Posts
Quote:
Those are factory on drum rear brake carsOriginally Posted by MichiganWildcat
I've got a 1985 IROC and the other day I pulled all the wheels off just to clean and polish. Then I noticed a small (1/4 inch) wheel spacer on both sides of the rear axle. Is this a factory thing or did someone along the way decide they wanted a different offset in the rear? JamesC
close
Why Does My Rear Have Spacers?
The spacer was apparently used on 16" wheels when GM switched from aluminum to iron drums, which created a .187 size difference. The spacer, however, seems to be hit or miss and essentially unnecessary. Even some disc brake cars received them. Mine did.
JamesC
JamesC
Mine is 4 wheel disc
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
Iirc, it has "GM" stamped on it if its factory.
