New GM TA 2002 WS6 rear spring part number: come inside to replace your old ones.
Old Jan 29, 2003 | 05:54 AM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Guys and Gals..............here is the GM part number for 2002 TA WS6 Rear springs......#10305134........dealer sells them for $84.60ea......gmpartsdirect sells them for $48.22...............they are the same WS6 rear coil springs for all year cars 82-92 that everyone is looking for.........so why buy aftermarket when you can have brand new WS6 rear springs on your car.......remember these springs fit in Camaro's also as not to leave anyone out......I put these springs in my 1992 Firebird in the rear and its much better tan those stock saggy ones I had in it..........
Old Jan 29, 2003 | 11:44 AM
SpeedJunkie's Avatar
Car: 88 IROC
Do these lower the car at all? I have the iroc ones that are all worn out and those sound like a good idea. Can I get them for the front or just the rear? What about the spring isolators in the rear?
Old Jan 29, 2003 | 06:10 PM
Car: 1996 Camaro
Engine: 3800 V-6
Speed.......that is the part number for just the ...rear WS6 springs....you can go to the dealer and get new isolators for like $20.00 ea........I dont have the part # for the isolators ( wish I did ).....but for that price thru ..gmpartsdirect.....you really cant beat getting 2002 WS6 springs for your ride........hope that helps.......
Old Jan 29, 2003 | 08:00 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can go to autozone and get springs for a 92 z28 for 37.99 front pair 55.99 for rear. here is the part #fcs5662s for front. rcs5635v for the rear.
Old Jan 29, 2003 | 08:45 PM
92GTA's Avatar
$25 a pair:
http://slponline.com/view_product.asp?PARTNUMBER=96306
Old Jan 29, 2003 | 08:46 PM
mrr23's Avatar
Engine: 360 HSR
can't beat that. too bad shipping is $25 also. total is $50
Old Jan 30, 2003 | 01:04 AM
Benny's Avatar
I believe 4th gen rear springs will raise the rear to high, we put some 2001 SS springs on a '90 IROC and it was really high in back, isolators were in the correct position also.
Old Jan 30, 2003 | 08:38 AM
Car: 1996 Camaro
Engine: 3800 V-6
Well that could be possible but for my car 1992 Firebird the rear springs were shot when I got it......drove it for almost a yr like that then I got this part numer for 2002 TA WS6 springs and got them for my car.......the car rides alot better with the new springs in the rear end and is much stiffer also...........the ones Zoned Auto sells are variable rate springs for our cars.....since alot of 4th gen parts do swap into our cars id figure I would post it and see what ppl think..........
Old Jan 30, 2003 | 09:29 AM
Car: 88 IROC
So will these springs raise the rear of my iroc? My springs are shot too and those look like a good deal cause i dont want to lower it. Are they progressive springs? I really would like to know if they will raise the car or not. Arnt iroc springs a little stiffer and make the car lower a little compared to regular 92 Z28 springs?
Old Jan 30, 2003 | 05:04 PM
mrr23's Avatar
Engine: 360 HSR
they will raise it back to factory height. they might be a little tall at first, but will settle in about 2 weeks.
Old Feb 1, 2003 | 08:04 AM
Eightyninef's Avatar
what is the 3 letter code on them. the little white tag with the part# and 3 letters.
thx
prolly something like TTJ, right ?
what was it on your old springs?
Old Feb 1, 2003 | 11:45 AM
johndinu's Avatar
Car: '89 GTA 350 hardtop
the question is if the ws6 or SS is lower than the TA or camaro v8... supposing you get ws6 springs for your iroc, if your rear is lighter, even for the same spring height it will sit higher.
also, take into acount that when you put (factory, stock, replacement...) new springs the car always will sit higher than it used to sit...
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1nastygta
Aug 8, 2015 07:38 PM
