Southern California Area Southern California Members.
Globalwest torque arm
Old Apr 15, 2002 | 09:11 PM
JERRYWHO's Avatar
I hope it works as good as it looks. The front mount is bolted under the trans cross member and the plate with the four holes is for the drive shaft loop so that will give you a scale for how long the torque arm is.
Old Apr 16, 2002 | 11:56 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
So where does that other plate attach to? I see what you were talking about last Sat.
That other plate is on one side only. Won't that tweek the lift of the car to that side only.
Oh yeah, I see Kevins new manifold there too.
Old Apr 16, 2002 | 04:06 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
Dwayne,
The other plate bolts to the floor and is attached to the tube that runs to the crossmember. So it shouldn't tweak the lift of the car to one side. Notice the bushing in the middle, IIRC the GW arm is 2 separate pieces attached at the bushing.
Jerry,
Can you adjust the pinion angle?
Old Apr 16, 2002 | 04:41 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Looks great!
Almost as good as it did in the passenger seat Thanks for the shot of the intake as well, that is going to be one monster Z28 :rockon:
Old Apr 16, 2002 | 04:51 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I'd like to see a close up of that manifold.:hail:
Old Apr 16, 2002 | 08:44 PM
JERRYWHO's Avatar
Originally posted by BretD 88GTA
Dwayne,
Jerry,
Yes you can but you have to remove the two rear bolts to do it.
Old Apr 16, 2002 | 08:48 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
That is a nice product! I have been thinking about getting a BMR, but I like the Global West...... I am looking into making the car take corners more so than drag racing. How much are the GW torque arms? You said you could go in with cash, e-mail me if you don't want to post it here... Thanks.
Jason
Old Apr 17, 2002 | 12:14 AM
JERRYWHO's Avatar
The intake still needs more work done before it's ready to bolt on.
Old Apr 17, 2002 | 12:15 AM
JERRYWHO's Avatar
One more time.
Old Apr 17, 2002 | 08:07 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Awesome Setup...
But won't this make changing the Jets a bit difficult?
Old Apr 17, 2002 | 09:40 PM
BrandenCali's Avatar
Randy veiw it more
Look At the fuel rails, he can prolly take those off in a matter of minutes, unbolt every thing else to take the system off flif it over an change the jets.. Thats what I make of it. I don't no a thing about Nos, but I think I would try running the plate. feed me info,
Old Apr 18, 2002 | 01:18 AM
JERRYWHO's Avatar
Re: Awesome Setup...
Yes the nitrous and fuel jets for this stage will be under the intake so it's set at 175 hp and not needed to be adjusted. The dual stage system on top of the intake is very easy to tune with a stage set at 50 hp and one set at 100 hp that will total 325 hp if all of them are used at the same time.
Jerry
Old Apr 18, 2002 | 10:37 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Jerry,
What do you think about the progressive Nos units that use large solenoids and you use one set of jets but the system regulates the solenoids for an "easy" into it Nos hit?
Your playing with a lot of juice. I like the hidden stuff though. Looks like you can anyways have a job as a plumber.
Also, did you have to add material because of the heads you'll be running or ?????
Old Apr 19, 2002 | 01:36 AM
JERRYWHO's Avatar
Jerry,
I don't like progressive units. The solenoids used for nitrous systems today are a on-off type valve and have problems when you try to make them open and close at a high rate. The best setup is to stage the amount of nitrous needed.
The main reason the fogger setup was installed under the intake is to make more room for more systems on top of the intake.
The intake had a real problem when i bolted it to my heads you had a good view of the pushrods so to make the intake gasket seal it needed some weld time. Now if i can just find some time to do the finish cuts it will be done.
Jerry
Old Apr 19, 2002 | 10:34 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I thought the progressive systems came with special solenoids that can handle the pulsing.
Old Apr 23, 2002 | 01:33 AM
Car: Yes...
Have you guys seen the new NOS direct port kits?
The NOS nozzles simply pop into the injector ports on the manifold, then you pop the injectors into the nozzles. Instant direct port nitrous. The kit also uses flexible tubing for easy plumbing. It looks like a sweet kit.
Old Apr 23, 2002 | 10:30 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I've seen them advertised and there was some discussion over in the power adder board.
So far all the advertisements say that they do not restrict the injector flow but I sceptical. I would also worry about the seals going from hot manifold temps to freezing cold to hot again. How long can the seals and maybe the injector tips take that?
I also don't think they'll fit under a Super Ram. A mini ram or that Holley thang for sure.
I do like the flexable hoses though.
Old Apr 28, 2002 | 02:54 AM
yeah he is for sure
going a diffrent route than what we would use for our set up's Dwayne. And as for me using Nos with Vortec's I donno how they would do with em. Probably not a good idea. Just stay all motor and see what I can pull. Peice by peice day by day, it's getting closer.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
