setting fuel pressure
Old Apr 5, 2004 | 04:44 AM
89redbird's Avatar
Ok i've read how to set fuel pressure
1) connect fuel pressure gauge
2) disconnect vacuum line
3) twist *** direction desired
4) plug vacuum line in
5) remove fuel pressure gauge
my only question is after i do that next time i look under the hood the little screw is all the way down again is it supposed to be like that i mean is it something to do with the vacuum i have no idea any help is good help thanks
Old Apr 5, 2004 | 11:28 AM
benz28's Avatar
Car: 87 Camaro Z28
Engine: 305 - 350 Swap
Transmission: 700-R4
I'm not quite sure how a screw can move up and down by itself without turning it. If you can explain that, maybe I can help. AFAIK, the screw on your AFPR should not move after you set it.
Old Apr 5, 2004 | 03:19 PM
chevyengr's Avatar
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
Try using a small dab of locktite on the adjusting screw to lock your fuel pressure in place. It seems weird that your fuel pressure regulator is doing this.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
