TPiS AirFoil
TPiS AirFoil
Hey guys-
I want to install a TPiS AirFoil in my throttle body, but I am not sure where to purchase a unit. I looked at their website, and it says they cost $59.00 and advertise an 11 HP increase... can anyone back that up? Seems a little exagerrated...
Will any Auto-parts store carry them? or do they need to be ordered?
-ONE2FLY
-ONE2FLY
do airfoils work or not right? well yes at some level they do help. at WOT they may help some amount, i dont think it would be 11hp unless it was a much more sizeable motor then a 305 or 350.
are they worth it is up to you, at some point they deffinately help but 59.00 is alot. i bought 1 made by slp for 34.95 with no shipping charges off ebay. the only shop that will have 1 will be a performance shop and it may cost a bit more. take a look around you will find at least 5-6 companies making airfoils for tpi/lt1 motors.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
I bought the CompPolymers one from Summit, $36.99. Its plastic, and should work fine. It actually looks a lot like the TPIS one, vs some other designes.
I'll prolly end up making my own eventually anyway, but for now it works..
-- Joe
-- Joe
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont bother. Save your money and buy a 52mm TB that comes with an airfoil. You'll get two mods for the price of one.
If you have the money to throw around, I say go for it. I have the foil made by TPI Specialties and I am pleased w/ it. I am sure it's not worth 11 hp but I feel it made a noticable increase in power. Little mods. like this can add up over time. Just my opinion.
I put an SLP Foil on my 89 350, not a huge difference but the butt dyno noticed a little better low end throttle response & a little more pull after 4500, I stress little. You can get the SLP one from SLP directly for about $36. A worthwile investment.
Jay
Jay
Car: 1991 z28
Engine: l98
I just got the TPIS one for xmas, I dont think it made a sizable diffrence, but it does sort of smooth out acceleration, and with a set of KNN's it cant hurt.
Thanks to everyone for the feedback, I didn't realize it wasn't as efficient as made out to be...
It seems like smoothing off the airflow into the TB would make a noticable jump in throttle response, so I am surprised at how many people don't think it's worth it, but perhaps a 52mm would make more sense...
I looked at it as a similar gain increase as K&N filters (5+ HP) or so. I still may roll with it, because little mods do add up over time. I guess I have to order them if they don't sell em in auto-parts stores...
At the same time, where can I get my hands on a 52mm TB? Are they easy to install?
-ONE2FLY
-ONE2FLY
Car: 1991 z28
Engine: l98
if you plan on doin some major mods to the motor, like cam, heads, headers, then you will benifit from a larger throtle body. its like goin from a 650 cfm carb to a 800 cfm on a mostly stock 305. throttle body sizing is sort of like carb sizing, stock on a tpi is like 650 cfm. quite enough for a 305 and good for a 350. it all depends on how much air you plan on moving, but the larger TB may hurt you till you get the rest of the motor up to speed with it.
To me it wouldnt make sense to build your motor around your induction. Of coarse I may be wrong, its just my opinion.
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I was just gonna say that. Why would he want a 52mm TB with a near stock engine of that ci. thats not going to be heavily modded?? That wouldn't be good. Get the airfoil. Its not going to make that much of a difference on a near stock engne, but it will make some for the good.
Car: 1991 z28
Engine: l98
In a way kevin you are right. If he were to go to a larger TB though, he might wanna think about portin and polishing his TB bores on the plenum, getting some aftermarket runners, siamese and port mathc them, and/or port match the stock base or get an after market one and do the same, along with some higher pound injectors, and an AFPR, that would make for some really good top end power, but then he may also wanna get a good chip or a custom burned job. Like I said, its good, but then he just built his motor around the TB.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
At 85% Volumetic Efficiency, a stock 305 that pretty much pulls til 4500 requires about 340CFM.
Save your cash.
-- Joe
Save your cash.
-- Joe
I am not planning on making my car into a beast, so all this talk about porting runners, new injectors etc... isn't in the near future, if ever...
I'm just trying to do a few little-medium bolt-on mods that will increase my performance over time. For the most part, I want to keep things pretty much stock since it's a 1990 and a collecters car as it is.
The biggest mod that I have planned for the car is ceramic coated headers, which will really improve horsepower.
It really seems like an air foil makes sense, since it prevents air from getting trapped between the butterfly valves in the TB, but I guess I'll find out after I install it!
Thanks guys
-ONE2FLY
Thanks guys
-ONE2FLY
Sanjay
Aug 12, 2015 03:41 PM
