ALDL Mating Connector
Old Aug 21, 2004 | 10:02 AM
Mastiff's Avatar
The newest thing I saw in search is 2 years old. Anyone know a source for the mating connector to the vehicle ALDL connector?
Old Aug 21, 2004 | 05:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you referring to a connector to plug into it for a test (diagnostic scan tool) cable?
Old Aug 21, 2004 | 05:47 PM
Mastiff's Avatar
Yeah, so I can plug in my laptop to the ALDL without having to remember which little holes to connect the two wires to.
Old Aug 21, 2004 | 06:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you going to use this just to retrieve trouble codes or do a diagnostic scan of the system? If it is just to retrieve trouble codes, it is cheaper and easier to use a paper clip in the two holes (pins "A" & "B") shown in this picture. If it is to do a diagnostic scan of the system, you will need to know where to put more than two wires.
Old Aug 21, 2004 | 08:54 PM
Mastiff's Avatar
No, I'm constantly programming new PROMs and I use the ALDL port to collect the serial data that comes out. I use WinALDL on my laptop and have a cable connected from the serial port to the ALDL connector. Right now the cable just has two loose wires at the end that I stick into A and E (I think, forget). Every time I disconnect I forget which pins to connect to, so I just want the right connector on the end of my cable so I don't have to think about it.
Old Aug 21, 2004 | 09:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Contact Craig Moates and he should be able to fix you right up. He is a member of the board and you can PM him and explain what you need.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
