Southern California Area Southern California Members.
A little 1LE fuel tank FYI....
Old Jan 24, 2003 | 08:45 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
After Jerry posted about the 1LE fuel tank on eBay I decided to do some investigating. I was almost going to bid on it but decided to wait. I have other items I want to buy that take priority – like a set of HMS strut mounts.
Anyway, a little reading at http://www.1le.net revealed some interesting information. Apparently ALL '90-'92 F-bodies received the "baffled" fuel tank.
The difference lies in the fact that the 1LE cars also received the longer fuel pick-up, bigger fuel pump, and double fuel strainer.
So, the tank itself is not rare. It's the parts inside the tank that make the difference. This will probably create a mad frenzy at the dealership, but I did run all the numbers with Dal at VanDevere Olds/Buick and ALL the 1LE fuel components are still available thru GM. I will be doing this upgrade at some point.
Old Jan 24, 2003 | 10:25 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
c'mon buddy you can e-mail the part numbers
Old Jan 24, 2003 | 10:27 PM
JERRYWHO's Avatar
Part numbers
Fuel tank: 10121026
Fuel sender unit (longer): 25094804
Fuel strainer (double screen): 25121120
Fuel Pump: 25116163
Jerry
Old Jan 24, 2003 | 10:28 PM
Engine: 3.6L
thanks Jerry This is my upgrase when my FP dies......hopefully in a couple years
Old Jan 25, 2003 | 12:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: A little 1LE fuel tank FYI....
I thought this was common knowledge?? Thats why the later model thirdgens dont die when you go around a corner with less than a 1/4 tank of gas.
And the only fuel tank still available for thirdgens is the later model one.
Here are pics of what the baffled tank looks like:
http://para.noid.org/~thresher/image...0&dispsize=800
Old Jan 25, 2003 | 03:17 AM
Car: Yes...
Originally posted by JERRYWHO
Part numbers
Fuel tank: 10121026
Fuel Pump: 25116163
Jerry
According to Dal, all those numbers have been superceeded by new numbers, but they do come up as available. It's just under $600 for all the parts.
Old Jan 25, 2003 | 03:29 AM
Car: Yes...
Re: Re: A little 1LE fuel tank FYI....
Kevin,
Prior to Jerry's post I had never looked into this before, so to me it was new information. Plus, there's still a bit of mythology floating around reagrding the 1LE cars so I don't think that many people are aware of this.
I do have to say though that I've never had a problem with my '88 sputtering going around corners with low fuel. Now, back in '95 I did have a dealership repair my fuel tank because it would leak at the base of the filler neck when full. I was always under the impression they had repaired the leak. I'm wondering now if the dealership just went ahead and replaced the tank all together. I'm gonna have to check this out.
Old Jan 25, 2003 | 08:41 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Tank
Usually they just replaced the leaky tank with a new one.
I was at my Chev dealer one day and saw 20 of them stacked up.
Old Jan 25, 2003 | 10:39 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
OK, my car will die out if I take a hard turn with not much gas in it.... ??? The only time the tank has been removed, was when I changed the pump, so I know it is the original......
Old Jan 25, 2003 | 11:36 AM
BrandenCali's Avatar
oh boy
Cant fill the tank up full on mine either it will leak =/ can't have it under a 1/4 tank around a corner and it may die?. Was there a recall on tanks?
Old Jan 25, 2003 | 05:11 PM
Car: Yes...
Re: Tank
The only thing that made me think they repaired my existing tank was that they charged $500 IIRC. That inlcudes the repair to the tank, a new fuel pump, new fuel strainer, and all the labor involved. All this work was also performed in one day. I was going out of town and had to have my car back ASAP. I took the car in on a Friday morning and picked it up at the end of the day.
The prices Dal just gave are as follows:
gas tank 279.93 each
strainer 17.47 each (1LE part)
fuel pump 63.46 each (1LE part)
sender unit 235.91 each (1LE part)
Don, do you know if there's a part number on the tank I'd be able to see while under the car?
Old Jan 25, 2003 | 11:00 PM
Dyno Don's Avatar
Nope, it's usually on the top.
Old Jan 26, 2003 | 12:32 AM
Benny's Avatar
$600!!!!!
Old Jan 27, 2003 | 02:34 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Is the 1LE fp better then say a Walbro 255?
The sender is the killer. What's so special here? Is it because it's custom for the baffled tank or would my stock sender work?
I haven't upgraded my stock stuff yet and I was going to get a walbro.
Old Jan 27, 2003 | 02:58 PM
Car: Yes...
Dwayne,
I now have all the current part numbers from Dal and am checking into them. It appears that the fuel pump #25116163 is the only pump now available from GM. Similar to the baffled fuel tank. There may or may not be anything special about it. It is supposed to be bigger.
The 1LE sender is supposed to be longer than the standard unit. It reaches to almost the bottom of the tank and allows the car to run reliably down to the last 1/2 gallon of fuel. A nice feature when racing.
The 1LE strainer is supposed to be a dual pickup piece, opposed to the single pickup standard piece.
The newer (read as baffled) fuel tanks are also supposed to be 18 gal. capacity.
Old Jan 27, 2003 | 10:24 PM
Kevin91Z's Avatar
Not even close Dwayne. The stock 1LE fuel pump would be designed to handle the stock rating of 245 HP max. An aftermarket fuel pump would support at least twice that.
Old Jan 28, 2003 | 12:42 AM
Benny's Avatar
Does this Walbro fit the stock in tank position or is it in line?
And how much do they cost.
Old Nov 18, 2003 | 05:13 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Not to bring this back from the dead or anything
But I just checked on the following numbers:
Sender - 25027221 - $513.11
Strainer - 25027354 - $32.00
The above part numbers are what chevy gave me after I gave him the 1le part numbers. I am trying to set my car up right, down to the last detail, but GM list is pretty killer.
The plan right now is to take the 91 RS tank I have get it cleaned, put in the sender and strainer for a 1le and use the walbro 255. Should work out to be a good combo.
PS side note... Anyone know if the gas tank "renu" process is any good?
Old Nov 18, 2003 | 05:28 PM
Car: Yes...
You might want to double-check that sender price. Here are the prices I got from Dal at Vandevere Pontiac-Buick back in January:
gas tank - $279.93 each - current part number is 10269091
sender unit - $235.91 each - current part number is 25027221
strainer - $17.47 each - current part number is 25027354
fuel pump - $63.46 each - current part number is 25116163
Old Nov 18, 2003 | 06:04 PM
Well, the prices he gave you are essentially the prices that show up at gmpartsdirect.com. GM list is the 513. I figure little details like using the 1le sending unit and strainer may be that little bit of difference.
...In making it one more day without having to fill up again
Old Nov 18, 2003 | 11:57 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
You mean my '92 should have an 18 gallon fuel tank?
When my needle reaches a tick above the E I fill up and get about 14 gallons. Does that mean I actually have 4 more to go?
My fuel dash light is out, otherwise I'd drive it longer just to see how far I go.
Old Nov 19, 2003 | 01:30 AM
bluethunder28's Avatar
No. The only "18 gal" tanks were in the "Players Series" cars. GM owned the cars and when the series end, all of the 18 gal tanks were removed and the racers could buy them outright. It costed $10,000 a year to race the cars and all cars were "sealed" so there wasn't much that could be done to the car so it was really a driver's series.
Old Nov 19, 2003 | 04:17 AM
Car: Yes...
I've read in magazines that some 1LE owners claim to have 18 gallon tanks in their cars and 1LE.net (while it was still up and running) was making this claim as well. As Glenn posted and from the research I've done this not correct. The street versions of the 1LE cars have the same capacity fuel tank as the non-1LE cars -15.9 gallons.
Old Apr 7, 2008 | 11:23 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Sorry to bring this thread back from the dead. My '88 IROC's fuel pump just died(1 week before the April 6th norcal gtg!) and I want to do the 1LE tank+guts swap. Anyways, my nieghbor works at a GM dealership and may be able to research the 1LE parts for me. Did anyone take pics of the 1LE parts they bought and compare them to shorter parts. I understand the double strainer and sender unit are longer and the later model tanks (90-92) have baffles. I just want to make sure I don't buy the same parts as I already have in my IROC. I've always been upset when fuel starve hits! Thanks in advance, Daniel U
Old Apr 7, 2008 | 01:56 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Exactly what I want to do!
Old Apr 7, 2008 | 11:33 PM
Dyno Don's Avatar
Just get yourself a '90-'92 tank and sending unit, put in the Typhoon/Cyclone GM pump and go. That will save you a lot of money and headaches.
Old Apr 8, 2008 | 09:45 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
So the sending unit in the 90-92 tank is the same as the 1LE? Will the Doulble strainer fit on the sending unit. If I could see pictures I may be able to make my own?
Old Apr 19, 2008 | 11:05 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
For future reference here's my thread link with pics.
https://www.thirdgen.org/forums/nort...=1#post3724608
Old Apr 21, 2008 | 03:38 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Did anyone take pictures of the 1LE sending unit they bought/installed? I'd like to see the "swinging pick up" mentioned.
Old Apr 21, 2008 | 10:08 AM
Dyno Don's Avatar
No such thing that I am aware of. Another one of those myths about 3rd gens.
Old Apr 21, 2008 | 10:43 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Do you mean the 1LE sending unit is a myth, or the "swinging pick up" is a myth? I have the 1LE sending unit part #. It's different from the standard sending unit part #. for your response. I just want the best fuel set up I could have got from the factory. I'm glad I don't have a true 1LE car, because I'd feel bad about using it as a DD. However, the idea to replace/repair my IROC with 1LE parts appeals to me. Kinda like slowly building a 1LE clone. Not for resale purposes, but to improve the cars performance.
Old Apr 21, 2008 | 03:30 PM
Car: Yes...
I think the confusion comes from the fact that there were two types of 1LE cars. The ones built specifically by GM for use in the Players racing series and the 1LE cars built for sale to the general public.
The 1LE street cars definitely had some extra goodies, but not some of the items of legend – i.e. the race-built cars had 18 gallon tanks with swinging pick-ups and dual strainers, so the street cars must have had the same.
Old Apr 23, 2008 | 12:59 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Does anyone know if GM galvanized these tanks? I took my 91 tank to be cleaned out before putting all new 1LE guts in and it appeared to have a factory coating that bubbled off the inside of the tank after the cleaning process. Did I ruin a good tank? Any help is appreciated. Daniel U
Old Apr 23, 2008 | 03:06 PM
Dyno Don's Avatar
The tanks are tinned. Like you would tin a part for soldering. The whole thing is dipped.
Old Apr 24, 2008 | 12:53 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Do I need to re-dip the tank? Can I with the plastic baffle inside?
Old Apr 24, 2008 | 11:16 AM
Dyno Don's Avatar
If you really messed it up, then kiss it good bye.
Old Apr 24, 2008 | 02:05 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Old May 3, 2008 | 01:21 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I ordered a fuel tank coating from Eastwood.
http://eastwood.resultspage.com/sear...=fuel+tank+kit
One you pour into the tank, the other you spray on the outside.
Old Sep 3, 2008 | 09:50 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
So has anybody else done a full swap to the 1LE style setup? I was talking to Daniel U and he mentioned that after changing everything over, that his fuel gauge would only read 3/4 full when the gas tank was full of gas.....The 1LE sender not compatible with the 1988 gauge on his car?
I can't figure it out. I could see an old 20 year old sender having problems with the float not going to the top. But not a new system.
Old Sep 4, 2008 | 09:45 AM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Its better to have a guage read 3/4 full when its full then 1/4 full when its empty.
depending on the guage floats, if they slide up and down on a tube not much you can do, if they are on a arm sometimes the arm can be bent.
Old Sep 24, 2008 | 03:07 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Really?I do good to sqeeze 13 gallons in my car on dead empty.
Old Sep 29, 2008 | 10:13 AM
Car: 1989 GTA
I'm the same way as Shadygrady. 12 gallons on empty, 12.5 gallons with the fuel pump humming and the car bucking like a horse.
Old Sep 29, 2008 | 04:47 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I guess when I do upgrade the fuel pump I`ll have to look into some of this.I would like to have a baffled tank,however,to do away with the fuel starve.
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
