Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
anyone with a Vette rear end on their 3rd gen??
Old Feb 26, 2001 | 04:42 PM
Black Beauty's Avatar
Car: 90 Camaro RS
ok...my friend has all kinds of parting vettes...Lets say he has a vette rear end for me. whats involved in putting that thing on? also will steve spohn suspension parts work with it? i have a A4 90 maro RS, drum brakes out back, 2.73 or something. let me know what im getting into pleez. i originally wanted to go with a disc brake thirdgen rear end....but then thought....if im gonna do a rear end swap might as well get the vette independent one. also....is it the same width as 3rd gen...will it fit the same wheels as my current rear end. i know some guys fit on 11s in the back and that was my plan....will it work with the vette one?? thanks
RICK
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Feb 26, 2001 | 05:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
I've never done it, but I know it's been done before. It's going to be seriously non-trivial though. Some major fabrication is going to be required.
Old Feb 26, 2001 | 06:15 PM
iroc22's Avatar
Try posting this same post under the suspension board you will probably get more responses.
Old Feb 26, 2001 | 08:06 PM
chevyboy07 91's Avatar
Independent rears suck for drag racing. So, if that's what you want to do w/ the car you'll regret it. The G-Trac steeda's have them and I see Honda's spank them out of the hole. But, they're awesome on "street course" type races. Also, you don't see that at all at the track on the big boys' cars
Old Feb 26, 2001 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As stated above, an independent rear suspension is good for road course type racing. Drag racing is better with a solid axle and ladder bars or a 4 link system.
NHRA rule book:
Cars running 10.99 or quicker that weigh more than 2000 pounds with independent rear suspension without upper and lower control arms must replace swing axle differencial with conventional differencial housing assembly. Example 1963-1982 Corvette.
So other than having to have axleshaft safety loops installed (another part of the rulebook), you can use it until the car goes quicker than 10.99 or you can lighten the car to below 2000 pounds.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 26, 2001 | 10:56 PM
Car: 90 Camaro RS
So i guess my best bet would be to grab a third gen disc brake axle....i mean i dont NEED a new rear axle but disc brakes sound really nice right about now. When i go to the yard, what years/models am i looking for...i heard some V6 firebirds had good gearing...GTAs? i dont know. help me out guys...also how much should i look to spend on the axle. with / without rotors/calipers? thanks
Rick
Old Feb 26, 2001 | 11:17 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
www.rareautodesign.com
This guy has done it before. He was trying to get more interest in developing a kit that would allow you to bolt in a C4 Vette IRS but never did.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
