Flickering lights
Old May 31, 2002 | 08:56 PM
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
Flickering lights
Don't know if I spelled it right.
My headlights and all my interior lights sometimes flicker.
Old Jun 3, 2002 | 01:27 PM
Tonyrodz's Avatar
Transmission: auto
I had the same problem w/my 89 formula--only the headlights would flicker--turned out to be a loose chassis ground. might want to check all your grounds for tightness--also make sure they're clean--to bare metal.
Also--not sure of other engine sizes--but there's a ground strap on the pass side head of the tpi motors near the firewall--see if you have that ground, and if so--make sure it's tight.
Old Jun 19, 2007 | 01:13 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: Flickering lights
hey, that ground wire you were talking about is this it? (wire is really flat and skinny?) also you have any idea what the metal bracket on the fire wall that has nothing to it is? thanks man. i also have the flickering prob. and i am trying to find a remedy... thanks.
Old Jun 19, 2007 | 01:20 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That's the engine ground strap, that may not be the cause of the flickering but might as well clean up the connection and upgrade that cable if you have 10 minutes to kill. There should be a ground connection through your battery terminal to sheet metal right in the area. Upgrade that connection as well. Then clean your terminals and tighten them then try again.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
