Fuel pumps
Old Mar 5, 2003 | 04:32 PM
converted's Avatar
Fuel pumps
Are the fuel pumps on 87 tpi iroc-z's electric or mechanical? If electric can it be switched to a mechanical unit and if so, how easily?
Old Mar 9, 2003 | 01:13 AM
SydwayzTA's Avatar
Car: 1986 Trans Am
its an electric fuel pump, not sure if you can switch to a mechanical, i'm sure theres some way you can, dunno why you'd want to.. but its a royal pain in the *** to get to, you gotta disconnect your exhaust behind the cat,(2 bolts) then you gotta completely drop your rear end, to get the tank out, to get the the fuel pump which is inside your gas tank. I just got finished replacing mine, wants very fun, lot of work, but its do able
Old Mar 9, 2003 | 08:50 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its electric. I don't think there is a mechanical pump that can deliver the pressure and volume needed to operate the fuel injection system. If your trying to avoid removing the tank, you can get an electric inline pump.
Old Mar 9, 2003 | 10:36 AM
vwdave's Avatar
I dont think anything short of a all out racing mechanical pump can deliver what a electric can. Even then, I doubt it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
