line lock installation question
Old Aug 19, 2004 | 06:45 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
where are we mounting thse puppies? anyone have a pic?
Old Aug 19, 2004 | 09:33 PM
IHI's Avatar
IHI
I've just got mine mounted on the driver side inner fender in front of the master cylinder. A freind of mine that has manual brakes in his 3rd gen mounted his to the flat "frame" under the master cylinder if you can imagine what I'm talkng about and it looks very clean there. If I pull the motor this winter I'd like to clean up the wiring and brake lines and will probably do the mounting on the "frame" like he did.
Kinda hard to see them since I painted then black, but they're there-old motor by btw
Old Aug 19, 2004 | 09:34 PM
IHI's Avatar
IHI
oops
Old Aug 21, 2004 | 01:53 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
ok.. thanks.. that looks like where i wanted to mount mine.. except i was going to pipe mine in between the mast cyl and the spliter.. thus saving adding an extra spliter.. would this work?
Old Aug 21, 2004 | 02:19 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Heres where I put mine
Old Aug 22, 2004 | 12:47 AM
IHI's Avatar
IHI
That should work if I'm understanding correctly.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
