Unexpected rear ratio find -- HELP
Old Apr 18, 2003 | 11:56 AM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Okay, I know one of the methods of checking rear end ratios is counting turns of driveshaft to turns of wheel (since I haven't actually pulled the diff. cover off to verify for sure), but what I got was very odd. I had 1 3/4 driveshaft turns to 1 turn of the rear wheel. Does this make any sense to anyone? Tell me my math is just all wrong, because this doesn't add up to anything that seems like a good number for rear ends...any help would be liberating to me right now! I know the rear end is stock, but don't have any RPO codes to referrence....it's a 1985 Trans Am Automatic with the LG4 motor rear drum brakes. Thanks!
Old Apr 18, 2003 | 12:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like only one rear wheel was turning.... in order for the turns-counting method to work, both rear wheels must turn exactly equally, as they would be if the car was driving down the road in a straight line
Old Apr 18, 2003 | 12:57 PM
lasher_350's Avatar
Engine: 5.7 L98
Yes, I believe only 1 was turning...I was on my own at the time...I'll have to recruit my friend to help next time...does that mean mine's a one wheel wonder?? I sure wish I had a posi unit that I could rebuild...
Old Apr 18, 2003 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup. One-wheeler.
Screw the various "approximation" methods; just pull the cover and look. This is why I tell people that, over and over again, but nobody listens; all these other things, from counting turns to "codes" to looking up the options a given car came with, are all full of possibilities for error. The one and only absolutely certain thing is to look at what's inside there; the parts cannot tell a lie.
Old Apr 18, 2003 | 01:24 PM
lasher_350's Avatar
Engine: 5.7 L98
Yeah, I'm beginning to agree with you there....Heck, 10 bolts and a little fluid isn't too hard to do to get accurate results. Will the ratio be punched in an easy to see spot? I know they punch the pinion and ring tooth count in them, separated by a colon, so I know what I'm looking for, but I don't know if it is easily visible or if I have to search really hard. It's on the outside of the ring gear, correct? I'm all for doing that this weekend. I'll post and let you know what I find....
Old Apr 18, 2003 | 01:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, outside edge of the ring gear. Or, just count the teeth on the ring and the pinion.
Old Apr 18, 2003 | 02:41 PM
lasher_350's Avatar
Engine: 5.7 L98
ewwww...counting....lol...I missed that day in school! lmao...j/k...
Reddeath210
Oct 6, 2015 08:20 AM
E Rod
Aug 28, 2015 05:17 AM
hectre13
Aug 26, 2015 08:17 AM
happyhapka
Aug 15, 2015 04:42 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
