ground straps on hatch struts
Old Mar 21, 2002 | 12:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
whats the ground straps for on my 84's hatch struts ? they are broken frayed, glass has defroster grid if it matters.. maybe it has soemthing to do with the power hatch release not working ?
thanks for anything
Old Mar 21, 2002 | 12:39 PM
grafx's Avatar
Car: 91 Camaro RS
Transmission: Pro-Built Automatic/Vigilante 2800
must be for defroster. I have a 91' with rear hatch motor and without defroster and my struts don't have the straps.
Old Mar 21, 2002 | 12:46 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yes, I believe it's for the defroster.
-Rich-
Old Mar 21, 2002 | 12:58 PM
MikeS's Avatar
That's exactly what they are for. Mine would pull lose every now and then when I open the hatch. Of course, I wouldn't notice it until I was trying to defrost the back window wondering why nothing was happening. With one of them unplugged, I don't even think the light on the defrost button will come on when you push it.
Old Mar 21, 2002 | 02:40 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
well thats crappy stuff, hmmm..... so how do they get so frayed and trashed ? hmm...
thanks guys !
Old Mar 21, 2002 | 10:36 PM
Vader's Avatar
Here's a "freak" thing on the '86 cars. My right ground connection periodically would loosen and fall off when I open/shut the hatch. Since it has the CHST light mounted on the rear glass like the Corvettes (the only year ThirdGen that did that was '86) the rear defroster will cycle on whenever I hit the brakes. The brake light power grounded back through the defroster relay and energized it. I finally got the correct amount of slack on the wire and got the connector seated well enough to prevent this, but is was a strange one.
As for the fraying, there may not be adequate slack in the wire coming out of the trim panel, and the wire may be chaffing on the trim or in the hatch closure. You should be able to extract some extra wire from the trim panel, splice on a fresh piece with a new connector, insulate the splice, and push the excess back into the trim panel.
Old Mar 21, 2002 | 11:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ones broken alread on one side, and th eother is getting ther,e im gona see about this sin ei already have headliner and trim out of car currently, might as well do it all at once
interesting about the 86 info, hmmm wild...
thanks !
punkmaster98
Sep 30, 2015 11:01 AM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
SG91camaro
Sep 5, 2015 10:27 PM
