Anybody thats swapped a TH400 in a thirdgen w/electric speedo....
Old Feb 4, 2004 | 06:16 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
how did you hook up a speed sensor?Any part numbers for what I would need to do it?I've been dealing without a speedo for two years and would like to have a working one eventually.
TIA,
Steve
Old Feb 4, 2004 | 08:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
You might be able to use a VSS from a 700R4 on a 400... the housings are the same diameter but the length might be different. You could try asking at the parts counter if there were any TH400 equiped pickups that had electronic speedos you could use the VSS from.
Old Feb 4, 2004 | 09:57 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I could be wrong but I belive the 700R4 sensor is smaller.I know the 2004R is smaller and I belive the TH400 is different from other GM automatic trannies because it is the only one with the larger output shaft and larger extension housing(with 6 bolts as opposed to 4).I wonder if there's something from a 4L80E that will work?Probrobly not
I've also tried to go to parts counter and dealerships but I seem to keep getting blown off by the sales guys.I guess they dont have the time to sit with me and figure it out.
Steve
Old Feb 4, 2004 | 10:18 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Here's the parts you'll need:
Sensor: #8655315
Reluctor: #8655291
They were used in trucks from the late 80's to early 90's that had the TH400 trans.
Old Feb 5, 2004 | 01:39 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
ALSO another option is to KEEP the manual speedo sender in the tranny and buy the converter ....
JTR (jags that run) and Street and preformance both sell these converters....They cost about 85 bucks....they screw onto the mechanical speedo VSS and plug into your Electric vss wiring... Its easier to install then redion the gears and VSS unit... and works great....
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
