proper TV cable adjustment for 86 LG4 (700R4)
Old Oct 29, 2001 | 10:29 PM
ONEFINE8T9's Avatar
i saw it done on my 85 LB9 trans am with the 700r4 but what about an LG4? to what i believe you push that little button type thing on the TV cable near where it meets to the carb (on the side of cable), push the actual cable towar the fire wall and let off the button. I than by hand open the throttle all the way, i will hear like little teeth click and it should be set. am i correct to assume this is proper TV cable adjustment???
sorry about the crappy description its kinda late
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Oct 30, 2001 | 03:16 AM
transfixleo's Avatar
To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old Oct 30, 2001 | 06:50 AM
ONEFINE8T9's Avatar
should i move the black tube towards the firewall or the front of the car?
Old Oct 30, 2001 | 10:35 AM
rondubbs's Avatar
firewall
Old Oct 30, 2001 | 06:42 PM
ONEFINE8T9's Avatar
thanx
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
