LG4 Fuel pump
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
LG4 Fuel pump
Did any of the carbed LG4's come with an intank fuel pump?
There seems to be some confusion in this area. Thanks
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
YES YES YES, do not let anyone else tell you different. I am not sure about ALL years, and I am pretty sure my 83 did not have an in-tank Fuel Pump. But my 1987 Formula did.
Matter of fact despite all what I was told about using my LG4 Fuel tank and it would not work with the TPI fuel pump, they were wrong, I just transplanted the sender unit, and the stuff that actually went into the tank, but used my original tank...
So, your answer is YES. But the pump is a low pressure model, and I also had another pump on my engine.
hope that helps.
John
hope that helps.
John
Engine: 406
Thanks alot okfoz, finally....my confusion is slipping away. I'm trying to help on the tech board and there seems to be alot of confusion...thanks again..
Here is what I dug up in the wonderful land of Parts & illustration Manuals...
LG4 (H) & Part #
82-84 On engine 6472366
85 On engine 6472408
86-87 On engine 6471252
87 IN TANK 25115461
BUT they had a Fuel Pump relay for the H engine in 86???
the "G" HO engine had the in tank Fuel Pump from 84-86
The in-tank fuel pump should have prevented the "vapor lock" problem that was experienced in 86, but it did not. Go fig.
LG4 (H) & Part #
87 IN TANK 25115461
Engine: 406
Thanks alot guys....no wonder a guy can get confused..here is the thread that got me started on this witch hunt.....
https://www.thirdgen.org/techbb2/sho...202#post707202
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
