easy manual fan switch?
Old Jun 23, 2002 | 04:08 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Axle/Gears: 3.45
Ive read the tech article on the fans. i dont need 10,000 fan options, I just want both of my fans to come on when I flip a switch and both to go off when I shut the switch off. What do i do to make the fans operate like this? I figure the simple way would be to just run a relay off the battery to the power wire for both fans, run a switch off the relay and ground both fans. Is that what I should do? I dont want to buy temp controled switches, relays, monkeys that switch the fans on, 4 gauge power cables, or any of the other extra BS, i just want my fans to work. Please someone give a simple answer.
Old Jun 24, 2002 | 12:28 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have the stock relays, fans, etc., tie a ground switch into the existing setup.
Old Jun 24, 2002 | 12:52 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
https://www.thirdgen.org/techbb2/sho...hreadid=114636
Old Jun 25, 2002 | 03:57 PM
Brian'sIROC's Avatar
Thanks for the diagram deadbird, that helped me out a whole lot.
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
TA8487
Aug 16, 2015 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
