fuel pump relay
Old Feb 7, 2003 | 11:06 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
fuel pump relay
'91 w/L98... is the fuel pump located on the firewall with the fan relays? I can't remember, but thinking i'm gonna have to change it, cuz the pump runs intermittently when i shut the engine off, instead of running steady before it shuts off completely... thanks...
KAM
Old Feb 7, 2003 | 11:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Should be with the other relays on the firewall next to the brake booster.
Old Feb 8, 2003 | 07:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The fuel pump relay is a more squared relay as opposed to the fan relay or the MAF(if so equipped)power and burnoff. Before you replace it try cleaning the socket and contact pins.
Old Feb 8, 2003 | 09:04 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
It's the middle of the three attached to the firewall. I spliced in a heated three wire O2 sensor.
Old Feb 10, 2003 | 02:48 PM
Car: '91 Z28
Axle/Gears: 323's
OK - I replaced the relay... next question I have is... when the engine is shut off, is the pump supposed to run for a few seconds or shut off upon engine shutdown? This is similar to the issue I started with, meaning that now when I shut the engine off, the pump shuts off. Before when I shut it down, the pump still ran for a few seconds, but was intermittent. On my IROC, the pump on it runs for a few seconds after shutdown, so... with this new relay in my '91, it shuts off when I shut the engine down...
KAM
Old Feb 11, 2003 | 06:56 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Two things supply voltage to the pump when the car is running. The oil sender unit has a switch that closes after approx 5lbs of oil pressure and supplies 12 volts to the pump as well as the fuel pump relay. The relay comes on when the key is turned to the ON position and primes the fuel rail, shuts down then re-energizes when the car starts. A sticky relay could have causes it to run after the cars was off, or possibly the oil sender mounted switch could have been staying on. The pump should shut off when the engine is killed. Funny you mention this, my 89 every once in a while did the same thing. I replaced the relay and the sender switch and I have not noticed the problem. I suspect that just maybe the oil sender switch was a little slow to turn off, I don't think it's an issue you should worry much about unless it runs for any length of time.
Old Feb 11, 2003 | 02:49 PM
Car: '91 Z28
Axle/Gears: 323's
the amount of time the pump runs has cut down drastically since i changed the relay, but now i'm thinking my '90 IROC has the same problem because it runs a considerable amount of time after engine shut down. i thought before that the reason the pump continued to run after shut down was to maintain pressure on the system, whatever purpose that may serve, cuz like as you say, when the key is turned on, the pump primes up the system. now on my IROC, it runs with high oil pressure constantly when the engine is on, so that switch may be causing that issue. i'll have to really take a look at both cars and compare notes. thanks for your responses...
KAM
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
