mods
Old Jun 12, 2003 | 10:29 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
mods
NA, 4bbl Projection 4Di, SBC 383 stroker, plenty of mods.
South side machine lift bars and SFCs
Nitto Drag Radials on Stock rims.
60' of 1.75"
best 60' to date of 1.61"
Old Jun 12, 2003 | 10:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
mmm, kewl i guess, was this supposed to be a reply???
if not
good short times, what is your ET and traps? what heads/cam are you running?
Old Jun 12, 2003 | 12:32 PM
FRMULA88's Avatar
Car: 1988 Formula
Best ET to date is a 12.49
Best MPH is 106
Some bugs to sort out:
Car is shifting way too early, around 4900 RPM
I'm a big fan of leaving the car in "D" for more consistancy, but a governor kit is waiting to be installed to raise shift point up to 6200
Old Jun 12, 2003 | 01:01 PM
Dewey316's Avatar
Car: 1990 Camaro RS
12.49 is pretty good for 106, i know guys in the 109 range that are still in the 13's
how do you like the 4Di? i have a line on a used one, but can't descide if i want to go that route, or buy a new comander 950.
Old Jun 12, 2003 | 01:09 PM
FRMULA88's Avatar
Car: 1988 Formula
I would go for the commander since its easier to tune/learn, plua has real time tuning capability. and progressive throttle body function.
I plan on upgrading my ECM and harness to the commander 950 in the near future.
starliner
Feb 9, 2016 08:18 PM
Quzyle
DIY PROM
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
