Burning Blue only under WOT
Old Sep 30, 2003 | 03:34 AM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Okay here is the story. First night I get the car running, all is fine, pulls great. Well I think I hear a rocker knocking, so I adjust the rockers. A Fuse blew, and didnt figure it out that day, so never got to test drive it. Next morning, I drive it to work, and the entire time its burning oil once operating temp is meant. Under any acceleration or just running in general it was burning blue. Later that night, adjust valves, make sure all is just 1/4 turn aftere knocking is gone. Now it only smokes under WOT.
Reasons I think it could be but was told it isnt.
1. Valve lash (Now Im told their are not related, but when all i did was adjust valve lash, and it only burns oil under WOT, makes me wonder)
2. There is about 3/4-1 full quart of extra oil. I put 5 quarts in oil change and somehow I guess it doesnt take this much. Do you think if I go back down a quart it will fix this?
Any other suggestions? I think I need a compression checker to check piston rings correct ? Any recommendations on which one, if this is the case. Thanks a bunch guys, car runs great besides this, and is lots of fun to drive.
Old Sep 30, 2003 | 11:10 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if it burns blue all the time or under wot, it's rings. been there done that.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
