2 1/2" cowl scoop
Old Oct 21, 2003 | 01:25 PM
84camaro350's Avatar
2 1/2" cowl scoop
i just bought a 2 1/2" harwood cowl scoop, anyone have any experiences putting a scoop on the oem metal hood?? i need advice on mounting and finishing.. thanks
84 coupe, chey 350 v8, edelbrock performer rpm intake and carb, chrome valve covers, edelbrock chrome breather, edelbrock chrome 14" cleaner, braided hoses, accel dis. super coil, th-350 tranny, centerline mag wheels, 11" wide rear cooper cobras
Old Feb 21, 2004 | 05:24 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
YEs
I have put a fiber glass scoop on my metal hood not too long ago actually. its a pain in the *** but easy.I cut this shape "U" out on the metal hood so its a real cowl induction. then i centered the scoop where i wanted it, striked a line all the way around , then sanded down roughly to where it was going to sit. then mixed up the body filler, put it on the bottom of the scoop. "the wide tracks on each side, also on the fron of it i put some. then i hurried and placed it on the hood, make sure everything is down on the hood. then i sanded it down to get flush then kept putting somemore filler to flush it better. there might be alittle crack but im gunna fill it.
Attached Thumbnails 2 1/2" cowl scoop-00_00007.jpg
Old Feb 22, 2004 | 06:20 PM
nolanr0413's Avatar
Car: Trans am
the good thing about adding the cowl to a stock hood is that the hod will fit perfectly.
Old Apr 21, 2004 | 11:26 AM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
crazy3rdgen, you didnt have to rivet the scoop onto the hood? Or did the putty act as a glue for the scoop to stay on the hood?
Old Apr 21, 2004 | 05:16 PM
Car: 2002 SS
Engine: Ls1
Hey
Yeah it acted as a nice glue then it was just a process of blending it in with the hood using the filler.. i did screw the hood down on the front where it was coming up alittle bit till it dried.. then i just unscrewed the screws and filled those little holes. its not that hard but i heard taking off the metal hood and switching to a fiberglass hood bolt on saves you about 20 lbs. its not bad so i'll just go with that later on a nice 4 inch cowl
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
dustint209
Nov 26, 2015 12:28 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
