Torque Converter Recommendation Please?
Old Feb 4, 2004 | 12:43 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
I am switching out my 4 speed T-10 for a TH350. Nothing wrong with the T-10, but I'm building a "Knight Rider" replica and that's an automatic so....
I've basically got everything for a TH-350 swap, but I'm not sure what range/brand for a torque converter I should get.
1982 Trans Am
LG4 305
4bbl Quadrajet, B hanger, CK rods
NO ECM from factory! This is a Canadian car
No cat
3.23 Rear end
Will be TH-350 with Transgo Shift Kit
I will probably eventually get a mild 350 engine for Saturday night cruising, I'm wondering if there is a certain stall range that will work nicely now, and down the road with a new engine? Perhaps there is a stock GM converter that would work well for me?
This will never be a race car, but I'd like it to be a fast street car. I don't want to snap my neck every time I accelerate unless I'm at WOT.
Any advice appreciated! I wouldn't be able to try any of this without all the help from this board already
:hail:
Old Feb 7, 2004 | 09:34 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I guess it all depends on what you are calling mild. 1200 RPM is stock, some Z28 TPI and Corvettes had an 1800 stall in them. I would say don't go over about 2200 if you are going to be running a stock engine for a long period of time. If it is only until summer, go to a 2500 rpm unit.
Again, what do you consider to be mild??? The cam has everything to do with what you need to run....
Old Feb 7, 2004 | 11:04 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Maybe you have the th350 already, I dont know. If not, Did you ever consider a 700r4 swap instead?
Old Feb 8, 2004 | 09:42 AM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Captain C,
I have no idea what I'll put in for a cam. I definately won't get a 350 engine for at least a year or two, so I want a torque converter that's streetable on my stock LG4. Honestly if GM put 1800 stalls behind the L98's, I doubt I'd ever want anything more than a 2200. So I think I'll cap there. Thanks for the help, I know I need to provide more info, but without an engine, that's difficult
SweetS10V8,
I didn't consider a 700R4 because 82 F-bodies are setup to swap to a TH350 much easier. Plus I have no ECM and don't care about overdrive, so a TH350 made alot of sense for me.
Old Feb 8, 2004 | 01:44 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Just a quick FYI, pre 93 4L60s/700r4s dont use an ECM
Only 93 and later 4L60Es do..
but since you dont care about OD, by all means the th350 is right for you!
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
