where is the timing mark
Old Mar 25, 2004 | 02:20 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
i have a 2.8 and can't find the timing mark on the balancer. there are 3 grooves in the outer ring but i don't think they are it. if they are which one do i use. thanks
Old Mar 25, 2004 | 02:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think you'll do better here than on T/GE.
Old Mar 25, 2004 | 04:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're in the right spot, unfortunately you have an 82-84, so all the marks are the same width. (85-89 just looks for the widest one.) There's three marks for use with a magnetic timing probe... but the only way I know for sure to find that #1 TDC mark is to get a little dirty.
1. Pull the coil wire off of the center of the dist cap and lay it aside out of the way.
2. Remove the #1 spark plug (front, PASSENGER side- not the front driver's side)
3. Put a socket and breaker bar on the big center bolt of the engine's crankshaft pulley
4. Put your finger over the #1 plug hole; try to create a "seal". If you can't work your finger in there, stuff a cotton rag (not paper towel) into the hole.
5. SLOWLY, turn the crankshaft pulley CLOCKWISE with the breaker bar until either (A) you feel pressure on your finger or (B) the rag blows out of the plug hole. (This step makes sure we get the compression stroke of the #1 cylinder.
6. Stick a phillips head screwdriver STRAIGHT into the #1 plug hole until you touch the top of the piston.
7. Start to slowly turn the crankshaft pulley clockwise again, as you watch the screwdriver. At some point, the screwdriver will stop rising. (This step finds top dead center of the compression stroke.)
8. When the screwdriver stops rising, remove the breaker bar/socket from the crank pulley bolt. Now look at the balancer. One of the marks should be lined up with the "zero" degree mark of the timing scale. This is your timing mark, paint it up with white-out (lasts longer) or chalk.
NOTE: If the screwdriver stops rising, and there's a timing mark "near" the 0 degree mark, but it's not exactly at the zero degree mark, well, guess what- the balancer's outer ring has slipped. A new balancer from GM is $50. All 81-93 rear wheel drive 60 degree v6's had neutral-balanced balancers, so you don't have to worry about getting your motor balanced. But for now, just to set timing, make a new mark on the balancer that lines up with the zero degree mark.
(The outer ring can slip because the balancer has a rubber isolation ring between the outer metal ring and inner metal hub. If the rubber deteriorates, the outer ring can slip.)
Hope that helped... if anyone knows an easier way for the 82-84 2.8's, feel free to post it!!
midge54
Dec 27, 2019 04:14 PM
Bryan F
Aug 18, 2015 02:28 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
