fuel pump relay? *pic*
Old Apr 3, 2004 | 06:43 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My picture seems to look different then vaders, just want to make sure.
In vaders pic it was in the middle, I think mine might be the one on the far left?
Old Apr 3, 2004 | 07:59 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
From left to right... Fuel pump relay, fan relay, fan relay.
Old Apr 3, 2004 | 08:03 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Oh Ok, got it.
I was going off this picture
Thanks!
Old Apr 3, 2004 | 08:19 PM
Vader's Avatar
That photo is an '86 model. It's also a Pontiac. We already know there are wiring differences between the two sides. The most certain method is to check the wire colors at the socket.
Old Apr 3, 2004 | 09:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't think so, he has a MAF car. Fan relays are up near the battery.
Old Apr 3, 2004 | 11:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
8Mike9 is correct, in IROCThe5.7L's first post. The relays shown from left to right are Fuel pump relay, MAF Sensor power relay, and MAF Sensor Burn-off relay.
Old Apr 4, 2004 | 12:38 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Hey... Looks like I was wrong... Guess I shouldnt assume so much.
Old Apr 4, 2004 | 03:25 AM
Vader's Avatar
It's not just you. The relays seem to be mounted in different orders/sequences in different years. I worked on a '91 that was quite differently arranged (probably since it was a MAP setup) and an '89 MAF car that was different than mine. That's why I suggested checking the wire colors.
Old Apr 4, 2004 | 12:27 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Got it!
Once again, thank you all for replying
Too bad I cannot drive my car, its April and 27 degrees here. Not to mention its snowing
Old Apr 4, 2004 | 05:22 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Well good news and bad news.
Good News: Pump would only prime the system to 15 Psi. Replaced the relay, now when it primes I get a solid 43 Psi.
Bad News: Still starts like crap after being ran. I went from 44psi to 15 Psi in 30 minutes. I then primed the pump, and it went back up to 44 Psi, and still started like crap.
I pulled the vacum line from the regulator when it was running, and there was no fuel, and my gage went up to 44 psi.
I have got to have a leaky injector[s]. I am going to start to take out my injectors tomorrow.
Old Apr 4, 2004 | 09:01 PM
Vader's Avatar
So far, you've proven that the pump is good, the regulator will maintain pressure and modulate it based on vacuum, and that teh regulator dosn't leak externally. It's still possible that the regulator is leaking through and your injectors are O.K. You need to perform the pressure leakdown check again with the fuel return line pinched closed.
Old Apr 4, 2004 | 10:29 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Vader, I do have a holley AFPR in my room waiting to be installed, so the intake is going to have to come apart anyway. Do you think I should send the injectors to Rich for the hell of it, even if they arent the problem? They are the stock ones and are pretty old.......
Old Apr 4, 2004 | 11:23 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Sending them is always good if you have the chance.
Old Jun 21, 2004 | 07:40 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: fuel pump relay? *pic*
Is there any difference between the MAF power relay and MAF Burnoff Relay??? They look identical to me. I bought the maf relay the other day, and wanted to install it, but hesitated as I could not tell which was which. Mine are installed in a smiliar arrangement!
Could someone tell me again what the relay on the far right is, down towards the lower edge of the photo. Thanks guys!
Will
Old Jun 21, 2004 | 08:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The MAF power relay & the MAF burn-off relay are the same part number, the only difference is the wires going into it.That other relay you are asking about is the fog light relay.
Old Jun 21, 2004 | 08:17 PM
norcalz28's Avatar
Thans bro, you rock! Also which one of the two is which, Power/Burnoff? I am getting an SES light intermitently and sometimes the car just shuts off seconds after startup. I am guessing the burnoff relay would most likely go bad first? I wanna replace the one most likely to cause the fault NOW and get the other one maybe tomorrow or something!
Will
Old Jun 21, 2004 | 08:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
From left to right in your picture, with the white relay being the Fuel Pump relay, the center one is the MAF power relay, & the one on the right is the MAF Burn-off relay.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
