hatch release button
Old May 6, 2004 | 11:05 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
so i am installing a dash button hatch release in my firebird. i got all the parts from a junkyard exept the switch, that i just purchased off e-bay. i have tested the slinoid (thing that makes it pop, that is a selinoid right?) and it works. but i am tryng to wire it up with little sucess. i have altered this photo to make things easy.
the black wire exiting left goes to the selinoid
the plug on the left goes to the switch
then three wires come out of it
orange grey and black
a brown wire comes from the relay, i think it is ground. a yellow wire goes into the relay that seemslike it would be hot, but the connecter has a brown wire with a white stripe. the same color code that connects to the parkingbrake lever.
there is an orange wire in the mix too, but it goes into the connecter but never goes to the relay?
any help would be great
Old May 7, 2004 | 10:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
TGO Main page>Tech Articles>1986 Wiring Diagrams>Hatch Release.
Follow the path to seek enlightenment....
(Or just copy and paste this link into your address bar:
http://92b4crs.tripod.com/86wiring/dia-pics/134-0.jpg)
Forgot to mention that you don't need the pigtail for the parking brake lever. It should already be there, along with most of the system, since the relay ALSO engergizes the "Brake" warning lamp when depressed. If nothing is under your dash and you have actually looked, then I'm sure I might be able to help.
The 14 gauge black wire goes to the solenoid. The yellow wire, as seen in the above link, connects to the neutral safety switch. I am not sure about the others but I know I can find out...
In the pic above, it looks as though the red/orange (can't tell the color offhand) wire from the switch goes to the relay. The GRAY wire from the switch goes to the Inst Lps system, the same as the one from the radio (hint).
Old May 8, 2004 | 06:07 PM
Xophertony's Avatar
Axle/Gears: n/a
thankyou mavrick. that solves it all. beetween this and tricksters digrams i am set.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
