MUCH Wider turning circle when converting to Rack & Pinion.
Old Jun 12, 2004 | 10:22 AM
Z RATED IROC's Avatar
Car: 89 Camaro
Just wondering how many of you have converted to a Rack & Pinion.
Did you go Power OR non powered rack.
4th gen Rack, Pinto Rack, Or Cobra rack?
Just wondering because Since I converted to a Power Cobra rack and have lost quite a bit of turning radius. The throw on the rack is just not as far as the stock system. which makes the turning ratio of the car allot wider than it was.
I have an Idea for something that will bolt on to the stock spindle and correct for the shortened throw. But I don't want to re invent the wheel here. Is there already something out there that will do the same thing???
Please give me your input so if there is nothing already out there Maybe I can have several sets made.
Old Jun 12, 2004 | 10:32 AM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
Ive got the flaming river manual pinto rack in mine...i like the way it turns. But really I cant give you a verdict on comparing to stock cause Ive got big slicks and a spool, which kinda kills my turning radius
Old Jun 12, 2004 | 10:49 AM
Car: 89 Camaro
Don't get me wrong, I love the benefits of the Rack & Pinion steering, Especially the Power rack. I just can't believe how much it increased the turning circle of the car. The wheels just don't turn as far.
Unfortunately I didn't do a before and after comparison on my turning circle. However, It takes me 3 lanes plus the lane I am in to do a U turn.... OUCH!
I'm pretty sure the device I am thinking of having built would be able to correct for the shorter throw, and make our cars turn in a stock circle. I'm just wondering if the reduced turning circle is limited to this rack, or are all racks causing the same issues...
Old Jun 12, 2004 | 03:45 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
does ur front end sit any higher with now with all of that weight taken off the front end?
Old Jun 12, 2004 | 06:00 PM
Car: 89 Camaro
I'm sure it would have. I can't make an accurate comparison though because I went to a coil over set up.
My back end came up about an inch though. I took out all of my stereo equipment...
Had to make room for the big blue bottle...
Old Jun 14, 2004 | 06:32 AM
89_3rd_gen's Avatar
Your ackerman has been changed.
The 3rd Gen steering arms are not design for R&P. You'll notice R&P steering arms are straight, ours are angled. Get on some turn plates or check your tire temps and you'll see. R&P on 3rd Gen's is for mostly for drag racing. You maybe able to heat the steering arms and correct this.
Old Jun 14, 2004 | 10:34 AM
Car: 89 Camaro
I just got off the phone with Vern at Pro Fab. I explained the device to him that would correct the problem. He liked the idea and said he will look into building them. He also said he is looking into building some light weight spindles too.
Old Jun 14, 2004 | 11:45 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
awesome, im still going to swap over to the R&P steering, my stuff should be here on wednesday, i guess ill be buying his spindls and the "correction" plates.
Old Jun 14, 2004 | 02:26 PM
Car: 89 Camaro
Yeah, Call Vern and tell him you'll be wanting those things too!
Maybe he'll get them built faster...
877-782-6470
By the way did you get the Bump steer kit with your kit?
It needs it.
Old Jun 14, 2004 | 04:00 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah i got the bump steer kit tooo. did he say how long itll be before those parts are for sale? id imagine itll be a while.
Old Jun 14, 2004 | 11:42 PM
Car: 89 Camaro
He didn't make it sound like it will be too long.
I noticed that my Bear Brake calipers are almost hitting the A arm when I have the wheel turned all the way. Not hitting, but have no room for adjustment.
It may just be an issue with that particular caliper. When you get your Kit all together let me know how much Clarence you have between your caliper and the A Arm.
I'm thinking that the Bear Calipers would be the limiting factor at this point, Not the Rack.
I'm sure Vern would make some modified A arms for me if I needed them. Those plus the "Correction Plates" would take care of all of the turning issues.
I'm going to get an alignment and see how it is after that. Then we'll see what more (if anything) needs to be done.
Old Jun 16, 2004 | 03:08 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
talk to him today, he said they are working on them already
Old Jun 16, 2004 | 11:32 PM
Car: 89 Camaro
Sweet!!!
Old Jun 17, 2004 | 10:40 AM
hre59's Avatar
Car: 85 IROC
steering radius vrs akerman
Akerman is a measurement in degrees. If you turn your wheel to the left, your left wheel will turn more degrees than your right wheel. If your steering arms on the spindle are bent the same and are the same length you will have equal akerman in both directions of steering. A normal amount af akerman is about 3 degreesfor a street car. If you want to change the akerman you will have to bend the steering arms either in or out in relation to the centerline of the car, depending if you want more or less akerman. More akerman will help on turn entry on tight corners but will cause scrub on long fast sweeping corners. What this boils down to is akerman has little effect on steering radius. As far as steering radius, if the rack is at the end of its travel and none of the parts are in a bind at full steering lock, your only option for decreasing your steering radius is to shorten the length of the steering arm on the spindle. The steering arm length is measured from the ball joint/strut vertical centerline forward to the outer tie rod end mounting point. Shortening the steering arm on a cast steel spindle is not recomended unless it's performed by skilled welder! IF THE WELD BREAKS YOU LOOSE YOUR STEERING TO THAT WHEEL!!!
Old Jun 17, 2004 | 11:32 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Re: steering radius vrs akerman
that makes sense. so what would be the correct thing to do? find a mustang spindle and measure from the ball joint to the outer tie rod mounting point, then have a set of spindles made for thirdgens that has the same distance from the mounting point to the balljoint?
Old Jun 17, 2004 | 12:04 PM
Car: 89 Camaro
I see what you are saying about the Akerman Measurement.
I agree about not welding on cast steel. There is no way I would take that chance.
What I have been talking about is a piece that would Bolt to the end of the Spindle in the same place the tie rod bolts. Then it would extend back toward the hub of the spindle. (Our spindles curve out toward the wheel making room for this piece)
Then your tie rod end would bolt to that piece at a precise point, Making it Act is if you had shortened the spindle arm.
With some calculations you could correct for both the Throw, and the Akerman by where you have the new attachment points.
One simple piece, No welding. It would act much as a Bump steer kit does to correct steering linkage angles.
Old Jun 17, 2004 | 12:38 PM
hre59's Avatar
Car: 85 IROC
steering radius
z rated iroc: I think your on to the fix for shortening the effective length of the steering arm. My back ground is in oval track racing where the steering forces are huge. So your mods make me nervous on the strength of your bolt on relocation point for the outer tie rod end. If you are drag racing on front skinnies than steering forces are less of an issue for you. I don't have any input on mustang spindles.
Old Jun 18, 2004 | 09:54 AM
Car: 89 Camaro
All of the bolts used are Twice the size of the ones on the tie rod end that comes stock on our cars. I'm not at all worried about strength.
Old Mar 10, 2005 | 08:10 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've collected the foillowing data tonight:
Stock 3rd gen steering box:
Turns Lock to lock: 2.5
Inches of pitman arm travel (total) 6.
Inches of tie rod travel each direction: 3
Mustang power rack:
Turns Lock to Lock: 3
Inches of travel (total) 5
Inches of tie rod travel each direction: 2.50
4th Gen Rack:
Turns Lock to Lock: 2.75
-- Joe
Old Mar 10, 2005 | 12:31 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Stock thirdgen spindle, aprox 8" center to center (ball joint to tie rod)
Attached Thumbnails MUCH Wider turning circle when converting to Rack & Pinion.-spindle-stock.jpg
Old Mar 10, 2005 | 12:32 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thirdgen spindle, modified. Approx 5" center to center, which is the same as a 4th gen spindle.
I just need to find someone willing to modify and properly weld the spindles..
Attached Thumbnails MUCH Wider turning circle when converting to Rack & Pinion.-spindle-mod.jpg
Old Mar 11, 2005 | 11:47 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Having the same issue on the turbo car. Really the only complaint with the rack conversion. Definitely interested if something comes out to solve it....
Old Mar 11, 2005 | 11:56 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
As far as I know, the spindles are steel. So they should be weldable by a competent welder.
I'm researching more into this. I'll post my results.
-- Joe
Old Mar 12, 2005 | 01:31 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
The people with the rack already goining, How bad is it? does it make it hard to even park the car in a parking lot?
Old Mar 14, 2005 | 07:03 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I spent some time looking at the 4th gen stuff. I'm not sure if its possible, but I was thinking.. A 4th gen spindle shoudl mount to the lower control arm because the ball joint should be the same diameter.
Then you cut off the top of the spindle, drill two holes and mount a bracket for the strut. Two birds, one stone. You get the better tie-rod arm angle, and ls1 brakes.
-- Joe
Old Mar 15, 2005 | 07:22 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
solution
I decided on a solution..
I "borrowed" this picture from a TGO member, I forget who, but thanks.
Anyway. Spent some time in the yard this morning measuring 3rd and 4th gens. The 4th gen spindle on the 3rd gen is possible, but the bracket VERY difficult to make.
Here is my solution. Either temporary, or permenant.
Attached Thumbnails MUCH Wider turning circle when converting to Rack & Pinion.-needed.jpg
Old Apr 2, 2005 | 09:55 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: solution
So I drove the car last night. Holy crap, it steers like ****. I mean, really bad..
The radius, that aint even funny.
And the 3 turns lock to lock is just junk.
Profab said if I send him my spindles, for $50 he will mod them to get the ratio back. I just hope it doesn't interfear with where the swaybar mounts to the control arm.. wtf.
Anyway. yeah it sucks. sucks hard.. I'll post more results.. Worse comes to worse, I'm going back to ws6 steering. This sucks.
-- Joe
Old Apr 22, 2005 | 12:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
good luck man. any updates??? and i was thinking to converting to rack and pinon but what are the benefits? is it even worth it to convert, i remember some1 saying its only good for drag racing.
Old Apr 22, 2005 | 12:21 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Spindles are in a UPS truck somewhere. Should show up monday.
I picked up a cobra rack, and re-worked the shaft. So its 2.25 turns lock to lock. Should turn like a charm I hope.
-- Joe
Old Aug 9, 2005 | 04:25 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
curious how this turned out??
Old Aug 9, 2005 | 06:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Worked great, but the steering shaft interfeared with my headers. I sold the k-member to a board member, and the rack, ujoint, and spindles to another member.
Then I stripped the car, and bought a '91, with a GTA box. woot.
-- Joe
Old Aug 9, 2005 | 07:57 PM
LOL, I've still yet to hear of someone running a rack on the street and enjoying it. I wanted to do a rack setup for roadracing, but maybe I'll just stick with a performance box, and forget about it....
Old Aug 10, 2005 | 10:46 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I wanted a Rack soooo bad, partly cuz the slick look it gives and I love changing anything I can on the car. But if it is turning out to be such a pain, then I guess I will stick to my aftermarket manual box. Very light weight too.
If there is a fool proof way to change to R&P let us know
Old Aug 10, 2005 | 07:25 PM
It seems to me no matter which way you look at it switching to a rack is a PITA
Old Aug 10, 2005 | 07:39 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
its not worth the trouble unless its a trailor queen or track only car. been there done that!
Old Aug 11, 2005 | 09:07 AM
Engine: LS3
Hey SLP IROC-Z .... I see that you painted a lot of stuff on your car domain site. Could you fill me in on moredtails about that. I live neer Boston and am gonna need paint in the neer future. Do you know any good places? Do you do side jobs? Is it really hard to do it yourself? THX
-Dennis
Old Aug 16, 2005 | 05:08 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
NO NO NO NO!!!
There are not enough words in the english language to describe how stupid that would be. When you heat metal, you change the way the molecules are aligned and alter the properties of the material, namely, its brittleness and ability to handle high stress loads. Heating/bending/cutting any steering component is just begging for trouble. It may be fine the first time you drive it, it may still be fine the 25th time you drive it, but what happens on the 26th time? the 100th time?
What happens when you are forced to swerve suddenly or hit a speed bump? All of this puts tremendous stress on your steering components.
FAST CAR + QUESTIONABLE STEERING = BAD!!!!!
Please for the love of g*d and the respect for the rest of us on the road DO NOT GO HEATING AND BENDING YOUR STEERING SYSTEM!!!!!!!!!!!!!!!!!
Old Feb 8, 2006 | 05:49 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
where did everyone get there stuff to convert. i am in the middle of ordering the rack and i need to know what other parts i need for this convert. any help will be great thanks
Old Feb 8, 2006 | 06:56 PM
Car: 89 Camaro
A Friend of mine is parting out his car and it has a complete Rank & Pinnion conversion, K Member, and Coil over conversion. The system is almost brand new! Maybe 500 Miles on it.
Send me an E-Mail for details.
zrated@comcast.net
Old Oct 23, 2006 | 09:21 PM
Dave88z's Avatar
Car: 88 IROC-Z/05 Silverado ECSB
Engine: 408 LSX
Transmission: 700-R4 reverse pattern/manual valve
Axle/Gears: 9"/4.11
Has anyone come up with a solution to the decreased steering angle?
Old Oct 23, 2006 | 09:55 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Just need to find someone that makes a rack that has the amount of travel stock thirdgen steering has. If someone does
Old Oct 23, 2006 | 09:58 PM
Dave88z's Avatar
Engine: 408 LSX
Axle/Gears: 9"/4.11
The problem isn't the amount of travel, it is the spindle design. The arms need to
be shortened like a 4th gen spindle to increase travel.
Old Oct 24, 2006 | 12:51 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Thats the dumbest thing I've ever read.
The racks being used do not have the travel required to be used properly with the thirdgen spindle design. It would be better to find an appropriate rack than cutting a welding a spindle.
Old Oct 28, 2006 | 05:11 PM
Dave88z's Avatar
Engine: 408 LSX
Axle/Gears: 9"/4.11
Don't you think that if they had a rack with enough travel everyone on this damn board would have bought it already! I agree that the stock spindle should not be modified, but it would be cheaper to have custom spindles made then a custom rack and pinion>
Old Oct 28, 2006 | 06:37 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Cobra / MGB Manual Rack & Pinion
Has the travel, just isn't power.
Old Oct 28, 2006 | 11:47 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Heh. new guys
The rack doesn't have the same amount of travel as the box did.
The arms are too long for use with a rack. Arms for rack cars are way shorter.
The rack you linked us to, is 3 turns lock to lock, not power, etc. Might as well use a manual S10 box.
-- Joe
Old Oct 29, 2006 | 01:46 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
No one called you a retard. Where did you come up with that? The idea wasn't dumb, just the wording. He said the probelm wasn't travel. Then said it was.
Perhaps your right and it is best to stick with the regular steering box.
Cutting the spindle arms seems to be the only answer. Just gotta make sure it is done properly.
Old Oct 29, 2006 | 08:38 PM
Dave88z's Avatar
Engine: 408 LSX
Axle/Gears: 9"/4.11
Originally Posted by anesthes
I'm a retard for spending soo much time and money on that car. But thats another story.
The problem is it wasnt meant to go there. The arms are too long for a rack, and the racks travel is too short for those arms. Just a bad combination, kinda like a bad relationship.
Stick with the regular box
(or buy a vette)
-- Joe
Or just find a company willing to make a custom spindle. I know for a fact that there are racing spindle/strut assys out there, but they cost a fortune and are pretty much race only items. If companies like belltech can make a drop spindle they should be able to make a shorter arm if there is a demand for it.
Old Oct 30, 2006 | 02:04 PM
83 Crossfire TA's Avatar
Why does everyone want rack and pinion steering? The fact is that an old school steering box is stronger, more durable, more reliable, gives the driver better feedback, somewhat adjustable…, in general, the vehicles that were last to go over to rack and pinion were those that packaging was not as big an issue or that feel/durability outweighed packaging issues. Vettes finally went over to R&P once they got so tight that it’s even a royal pain in the *** to work around the R&P (try doing anything in that area on a C5…)
The only reason that rack and pinion ever got popular is that it’s smaller/easier to package, well that and clever marketing… in the ‘80’s as it got pushed onto the motoring public (sheeple) as a feature or advancement, it always got listed with other useless crap that people started to think was better then more traditional designs, “The new chevy celebrity… with front wheel drive, rack and pinion steering and macpherson strut front suspension!” Woohoo!
Old Oct 30, 2006 | 09:37 PM
Dave88z's Avatar
Engine: 408 LSX
Axle/Gears: 9"/4.11
I will agree that switching to a rack for any type of road racing/street third gen is a waste of time. In that case I would stick with a steering box, it would be a lot stronger and safer. However, for a drag car that will see limited street use, I like the fact that a manual rack can take a lot of weight out of the front of the car. Each person has there own agenda for their car, and you should buy the right parts accordingly. I am determined to find a way to make the rack work a little better for my application. I don't mind that its not power, I just wish for a little better steering radius. This will just be another challenge to overcome-and to me that is what makes hot rodding fun. Just my .02!
