bushing materials, spohn torque arm...
Old Jul 1, 2004 | 12:54 AM
91L98Z28's Avatar
Car: Z28
I'm getting quite close to the rebuilding of front and rear suspension on my 91.
have a few questions.
(1) anybody know actual durometer values for TRW, 1LE, and MOOG rubber bushings? or at least a "stiff, stiffer, stiffest" order? anybody know if the various 1LE part numbers from GM are actually 1LE parts and not just correct fit with soft rubber?
(2) has anyone adapted a rubber bushing for the front of spohns' torque arm (the one that has it's own crossmember and mounts to the chassis - not the trans)?
background for anyone who wants to dig deeper or give advice/suggestions/comments
the car is basically a glorified highway cruiser for me. no autocross or competition or anything. I just need to tighten it back up. I'm staying with stock springs and swaybars. The car came with the FE2 package so I'm pretty sure it already has the 36/24 swaybar setup with hollow front bar - it has the small hole at each endlink. Has KYB shocks for the time being, which seem fine to me if not a bit stiff.
my goals is to stiffen the weak parts (SFC's, box the LCA's and the panhard rod) and use new rubber bushings everywhere (high durometer/1le where possible/available) except the swaybar endlinks (will use nylon or poly there). I'd love to use the spohn TA as well, but am unwilling to use a poly or spherical bushing..so until I can figure out a rubber bushing setup, the stock torque arm stays. (steve spohn, if you read this, the day you offer a TA for T56 with a rubber bushing to replace the poly bushing, i will order one!)
basically i'll be doing everything. strut mounts (stock type), a-arm bushings, balljoints, inner/outer tierods, idler and centerlink, lca bushings, panhard bushings, TA bushing at trans, swaybar mount and endlink bushings, i think that's it.
Old Jul 1, 2004 | 10:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Concerning the 1LE bushings. The ZZ4 HO 350 conversion manual mentions rear control arms with "high-durometer (50K) bushings. These harder bushings reduce wheel hop under hard acceleration. (For comparison, production bushings are 11K)."
The 1LE 36 mm front bushings are GM P/N 14094389, the 24 mm rear 10037104 (and the poly endlinks 10221779). I can only assume that they too are the higher durometer. I used both front and rear for a while but eventually swapped them out for greaseables. Check sig. By the way, you may still be able to purchase the 1LE lower control arms, P/N 10164151, mentioned above--at least GMpartsdirect.com shows a good number:
JamesC
Old Jul 8, 2004 | 12:40 AM
91L98Z28's Avatar
Car: Z28
thanks for the info. I think I've got everything I want figured out, with exception of the torque arm.
Does anyone at all have any idea how to set up a spohn TA with a rubber bushings on the trans end, instead of the poly?
I don't understand why this isn't a popular option. the rubber will deflect for axle articulation just fine and not bind like poly (have experienced this first hand), and won't be obnoxious (monetarily and audibly) like a rod end. i guess "rubber bushing" just isn't as fancy as poly or spherical...too bad; i'd gladly pay the spherical price for a rubber bushing. too bad a standard LCA rubber bushing or A-arm rubber bushing (or something) coudln't be swapped in.
i really need to do something about the suspension (see times in sig) but just not enthusiastic at all about going poly or spherical.
Old Jul 8, 2004 | 01:45 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Just buy the Spohn setup and replace the poly end 3/4"-16" fitting with a rubber one.
Here you go- same exact fitting in rubber for $26
http://www.airride.com/productinfo/p...ice=%2426%2E00
Old Jul 8, 2004 | 08:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
my question is, if you're doing this for a non competition cruiser, why are you buying the aftermarket TQ arm in the first place?
Old Jul 10, 2004 | 03:21 PM
91L98Z28's Avatar
Car: Z28
vsixtoy - thank you! that rubber rod end looks perfect to me. going to have to give it a try and report back..
mrdude_1: why not? I mentioned that it's not a competition car to explain why I'm not interested in spherical or poly (read: things that increase noise, vibration, etc.). I still want it to have the best handling and traction possible, just without compromising the ride on my 60 mile trip to work! I already have a heavily "compromised" car, don't need another.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
