4th gen dash swap problems
Car: 1988 GTA
well I haven't gotten very far - seems all the diagrams I am looking at from searches have different 3rd gen colored wires...please help!!!!!!
I have an 88 GTA and I am using a 98 v6 firebird dash.
so far my problems are:
- only the 2 outside holes line up on the new dash (top side)
-sits closer to drivers door than pass door, but steering colum and outer holes on dash line up (about 1" off center)
- heater box is severly in the way
- headlights not popping up (parking lights and dimmers work fine though)
and I haven't even started on the cluster...I'm worried I got in too deep - I prey you guys can help a brotha out here - I'm begging!
lemme list a few of my wiring issues:
3rd gen:
headlights:
yellow
yellow
brown
red
cream or white (i'm a lil color blind)
orange
4th gen:
black
yellow
tan
red
orange
red
brown
foglights:
3rd gen:
gray
black
brown
brown/gray stripe
purple
4th gen
tan
black
brown
purple
yellow
trunk switch
3rd gen
black
gray
orange
black/white stripe
4th gen:
black
black/white stripe
please, please, please help!!!!
3rd gen:
headlights:
yellow
yellow
brown
red
orange
4th gen:
black
yellow
tan
red
orange
red
brown
foglights:
3rd gen:
gray
black
brown
brown/gray stripe
purple
4th gen
tan
black
brown
purple
yellow
trunk switch
3rd gen
black
gray
orange
black/white stripe
4th gen:
black
black/white stripe
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Im in the processss of installing mine to.
You have to drill new hole for the dash in the fire wall to get the rest of the bolt in.
Its normal for there to be a 1'' gap on the drivers side and sit fine on the pass.
Youll have to modfy the a/c ductin to the heater box. Either useing the old ductin or new. Search and youll see how other have done it.
Just got all my headlights etc.. working today. Ill find my wire diagrams I used and let you know about the pop up lights when I find them among my mess of papers.
The trunk I don't know about yours? my 3rdgen only had two wires so mine was easy.
The guages are easy. If you need info on them let me know.
Transmission: 4L60e
Axle/Gears: 9 bolt
All right. heres the diagrams I used. they are for a '95 Bird but I used them to hook up my headlights, fog, and dimmers for my 2000 switches. may be a little different from yours, but just look at the functions of the wires and color wont matter. The popup function should be the yellow wire on the 4thgen headlight wire. split it into 2 before the healight dimmer switch, 1 to the switch the other to the healigh motors. As long as you know the functions of the 3rdgen wires it should be easy following these diagrams.
Transmission: 4L60e
Axle/Gears: 9 bolt
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
i think i know where the prob is on your headlamp doors... you have a door modual that has a white wire...and starting in 90 and up they switched from a white wire lead out of the headlight switch to using the brown parking lamp wire... i think the best way to fix your problem would be to get the headlamp door modual from a 90 or newer bird. i can not see any way to get the correct signal to your modual you have now without doing that... you need a hot at all times fee to the white wire only when the lights are off... and the yellow wire is for when the headlights are on... everything else on your modual is the same as the newer ones... let me know what you plan on doing and ill look some more on what might work...
for your hatch release if you havnt got it working yet
you need to hook the black/white from 4th gen to 3rd gen blk/wht
blk from 4th gen goes to blk 3rd gen ground the others are for relay and hatch motor... let me know if you need more help on that
Omega
Oct 1, 2015 02:20 PM
