A/C delete and now no fan!
Old Sep 10, 2004 | 01:26 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I just finished doing the a/c delete on my Formula and used formul8!'s post on how to keep the 4 speed fan to the letter. Now the fan won't come on at all. I have 3 electrical connectors that are now unused at the heater box and two at the compressor location. I removed everything from the condenser on back to the firewall so none of the original system remains except for the wiring. I've ckecked everything I can think of and still no fan. Anyone have any ideas?
Old Sep 10, 2004 | 01:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need the high-speed relay. Put it back if it's missing.
Old Sep 10, 2004 | 02:00 PM
Mongoose's Avatar
Car: 90 Formula
Big,square looking thing with several wires going into it mounted on a sheetmetal bracket? It's attached with the same results.
Old Sep 10, 2004 | 02:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you're using your car's old A/C wiring, you should have apurple wire from the relay to the blower motor; a black wire to the blower motor housing; the relay; red wire from the relay to another red wire, they connect together about the resistors (circuit board looking thing with 3 "springs" on the inside and 4 terminals on the outside); the original control head.
Check to see if you have 12V, ever, anywhere in the system. If not, check the fuse, and make sure the main power supply wire (brown) is still hooked up to the control head.
Old Sep 10, 2004 | 04:24 PM
Abubaca's Avatar
Mike, I just reused my original fan motor. A few washers/spacers and she's good to go. I used some silicone sealant for the cracks, but I test ran it with the gaps open, and the fan inside the car was just fine.
...I'm gonna make a nice aluminum spacer "when i get time". LOL
Old Sep 10, 2004 | 08:05 PM
Mongoose's Avatar
Car: 90 Formula
I'm reusing my original fan motor as well. I'm wondering if any of these connections for the a/c system may have something to do with it besides the high speed relay. I'm also thinking that I may have just overtightened the screws and compressed the foam gasket too much and the fan may be jammed against the firewall. I'll check tomorrow when I have more time. Any other ideas?
Old Sep 12, 2004 | 08:53 AM
Mongoose's Avatar
Car: 90 Formula
Did a check yesterday and I've got voltage all the way up to the relay but no voltage from the relay to the motor so I'm thinking bad relay unless anyone here can offer any other options. A response from another board said something about adding a ground wire from the motor to ground but the post here by formul8! didn't mention that. Anyone?
Old Sep 12, 2004 | 03:47 PM
Mongoose's Avatar
Car: 90 Formula
Relay is no longer the culprit. I replaced it today and now have voltage up to the connector for the motor. Now to pull the motor. What are the odds on both the relay and the motor going at the same time?
Old Sep 15, 2004 | 07:17 PM
Mongoose's Avatar
Car: 90 Formula
Problem solved. Motor wasn't bad after all. Turns out a small spacer thing underneath the fan cage was causing it to butt up against the firewall. Removed the spacer and after some carefull tightening all is well.
codeysabatini
Nov 10, 2015 04:07 PM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
85Special
DIY PROM
Sep 3, 2015 04:21 PM
