headlights.....???
Old Jun 10, 2005 | 07:41 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
headlights.....???
ok i have a 92firebird and the lights pop up but they dont come on. it just happened all of the sudden both dont turn on. i know the bulbs are good so....i need help
Old Jun 10, 2005 | 10:41 PM
7plagues's Avatar
found problem....brake pedal cut through some wires...guess which ones.
Old Jun 11, 2005 | 02:03 PM
7plagues's Avatar
right...i redid the wires, it was a light blue, black, light green, and a tan wire. and my lights still dont come on. im completly lost.....help would be greatly appreciated....
Old Jun 11, 2005 | 04:48 PM
7plagues's Avatar
please....i would like to drive my car tonite all my other lights work(fog, tail, blinkers) its just the headlights. and i re-rewired them and i soldered them all nice and heat shrinked them and all....and it still doesnt do the trick....
Old Jun 11, 2005 | 07:10 PM
7plagues's Avatar
pretty please? is there a switch or a relay someone could tell me about....or anything....
Old Jun 11, 2005 | 07:23 PM
7plagues's Avatar
Update!? kinda strange twist of events i was thinkin i wonder if the highs work. so i hit it on and bam they worked...and then when i hit them off the LOW beams worked aswell?!!!? Looks like i might be goin to the track tonite!!!! wooot
Old Jun 11, 2005 | 09:20 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
There is a connection under each headlight so you might just want to try those. I had a similar problem and one of them was unclipped and after snapping it back together they both worked? Im assuming you've already checked the fuses as well.
