Parts Wanted 2006 Looking for something in particular? Ask here.
WTB: Dual Fan set-up
Old Oct 9, 2005 | 08:21 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Like it says - I am looking for a dual fan set-up with upper and lower radiator brackets. I have the wiring on the ECM wiring harness.
Old Oct 9, 2005 | 09:58 PM
zerokill78's Avatar
Car: 93 z28,89 formula350 92 formula350, 92trans am 350 6-speed,1992 3.1 firechicken,1991 z-28 350..1986 hearse
Engine: several350tpi,lt1,3.1(haha)
Transmission: auto...6-speed
$100
Attached Thumbnails WTB: Dual Fan set-up-dual-fan.jpg
Old Oct 9, 2005 | 10:45 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I dont have the upper and lower brackets but have both fans for $40 shipped. I have seen the brackets sell on Ebay pretty cheap....jt
Old Oct 11, 2005 | 03:52 AM
Car: 1986 Iroc-Z
JT - Is that both fans mounted in the Y bracket? Do you happen to have any of the hardware that mounts them to the top and bottom radiator supports?
Tony
Old Oct 11, 2005 | 09:42 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Yeah, both fans are mounted to the Y brackets. Not sure if I have the hardware but they are pretty common 13mm bolts. They can be found at autozone, napa craquest etc pretty cheap.........jt
Old Oct 11, 2005 | 04:00 PM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i have the dual fan setup for 100.00 shipped. email ron09517@aol.com
ZEEYAA
Apr 16, 2023 08:29 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Night rider327
Oct 9, 2015 09:25 AM
91 SrS
Oct 7, 2015 04:32 PM
