speed bleeders for brakes?
Old Jun 12, 2001 | 04:02 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
How exactly do they work?That pretty much sums it up.I've always bled my brakes with 2 people so i'm not sure of how they work.Thanks for any replys....
Old Jun 12, 2001 | 11:01 PM
Jza's Avatar
Jza
I have them on all four corners. It's a bleeder screw with a spring-loaded checkball and a coating on the threads that prevents air from entering the system. You just back it out a quarter turn and pump the brake pedal 'til you don't see air bubbles, then move on to the next one. I think they're great, since I do all my work myself.
Some magazine article recently described a way to do it yourself with regular bleed screws though. Apparently you just back out the screw a tiny fraction, enough to let fluid out, but still give some backpressure when you depress the pedal.. I dunno, but since the screws were only $20 for all four, it works fine with me.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
