Need some popup headlight help
Old Apr 9, 2002 | 08:51 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
My drivers side headlight goes up just fine but won't go down with the switch. All I have to do is nudge the manual **** and it quickly spins and goes down. Is this likely just a lubrication issue and if so how far apart do these motors come to get at whatever needs to be lubricated?
Before I start tearing things apart senslessly I figured I'd ask
Old Apr 9, 2002 | 10:17 PM
Nightcruzer's Avatar
Car: Trans Am
I believe the 85 is the older (3 relay) system. The symptoms sound like a high torque switch (HTS) is wearing out or dirty motor brushes. Either way, it is much easier to remove the whole headlight assembly as one piece, there are only 4 bolts. After you have the assembly out you can remove the access cover to inspect clean the HTS and brushes without having to disassemble the entire motor housing.
Here a couple of threads relating to this.
https://www.thirdgen.org/techbb2/sho...&highlight=HTS
https://www.thirdgen.org/techbb2/sho...threadid=73250
Old Apr 13, 2002 | 01:33 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Thanks Nitecruzer that was it! Works great now.
Old Apr 14, 2002 | 01:16 PM
Car: Trans Am
Glad I could help
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
