Looking for v8
Old Oct 22, 2007 | 07:37 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Looking for v8
lookin for a 350 (will consider 305), preferably not to far from 75460, have around $500 for it atm (but i'm saving, so if you've got somthing you want more for and are in no rush to sell, i'll look :P) running is great, rebuildable is fine, don't need intake heads, carb/tbi, (notice i say "need" doesn't mean i dont "want" :P) as long as its got block, crank pistons, connecting rods, etc
thanks,
chris
ps, this is for a 87 maro with a 700r4
Old Oct 22, 2007 | 11:34 PM
chevytt350's Avatar
Car: 1982 Z-28
Transmission: th-400
Re: Looking for v8
i have a 327 0.60 over, needs a crank, comes with tune port heads
i have a 350 4 bolt main, standard bore
i have a 305 standard bore out of my 82 Z-28 that doesnt even have 80,000 miles yet
i want
150.00 for the 327
300.00 for the 350
250.00 for the 305
all are complete with heads to oil pan, except 327 need crank and it is dissassembled
Old Oct 23, 2007 | 06:17 PM
91 Formula's Avatar
Car: 1991 Formula T/A
Engine: 415ci stroker-626rwhp 636flbs
Transmission: 5-speed
Axle/Gears: 4.56 posi
Re: Looking for v8
If your still lookin, I have a H.O 305 that has had some work done. It is a full roller motor with the heads having bigger valves higher comp ratio. It dynoed out at 302hp at the flywheel and 325flbs Pm back if you still need. We'll talk money after
Old Nov 6, 2007 | 10:07 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
Re: Looking for v8
if youre still lookin I have a tbi 350 out of an 88 k1500 supposedly stil ran it has 115,00o miles. It is a complete engine.
Old Nov 7, 2007 | 09:00 AM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: Looking for v8
unless this deal falls through, i'm done looking
