NEED 19LB 305TPI FUEL INJECTOR!
Old Mar 19, 2008 | 09:47 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
I was fixing a fuel leak and found out that one injector on my camaro had the tip broke off. I am looking for an injector that has the ceramic tip on the end i believe they will work from 85-87 305 TPI. If anyone can help let me know. -Matt
Old Mar 19, 2008 | 11:20 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: NEED 19LB 305TPI FUEL INJECTOR!
i was wondering why don't you replace that old type injector with the bosch design 3.. the technology is far superior to the 25 year old injector you have. i really like the way my car is running with the injector. they have the 4 hole discharge plate for a wide spray pattern ang good atomization which is key
you can get a whole set for about 140.00 .. they are really worth looking in to
Old Mar 20, 2008 | 12:20 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
I'm pretty sure I have a compleate set for 50 plus shipping if you're interested. They are from an 86.
Old Mar 20, 2008 | 08:27 PM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Ok well hear is a pic and the part number on the injecor is 5235047.
Old Mar 23, 2008 | 12:59 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
I have a complete set of 8 in great conditions, $50 plus shipping...
Old Mar 23, 2008 | 05:01 PM
19CAMARO85's Avatar
i have a set coming in the mail so i hopeing that it will fix my problems. thanks for all the responses . ill let you know how everything works out. -Matt
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
