BLACK GTA DELUXE DOOR PANELS! COMPLETE! TWO SETS!
Old Oct 23, 2008 | 07:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
one set is an 8 on a 10 scale. the only defects apperance wise is when the sun shines on the drivers side panel. whoever had the panels before me wore boots and you can see the light scuffs where you kick your leg to get out of the car. there is one spot where the carpet is bald where it meets the leather. this is hardly noticeable, and is not loose.
the door tops are seperate from the panels. they were like this when i purhased them. one or two of the metal brackets on the back are loose from the cardboard, but these panels were installed on my car for 5 years and held tight with NO rattles or loose spots.
included:
2 door panels
2 door tops w/weatherstripping
2 armrests
2 inner door brackets that you MUST have to mount gta type panels.
all screws and screw covers
painted black door handle trim(professional)
manual door lock blanks(rare)
only thing missing is the trim around the top bolt on the armrest. when i unbolted them, the piece crumbled into about 10 pieces.
it doesnt loook all that bad without them. if you arent a third gen purist, youll never notice.
200+ ALL SHIPPING!
my second set is a 7 on a 10. the carpet is barely loose in spots, and i dont have all the screws and hardaware. same as above, a few of the fasteners on the back are looose from the cardboard, but could be fixed with some type of glue or epoxy. i have never remounted these after removal, so i dont know how tight they fit, but were very tight fitting when removed. door tops are MIA, but i might have a set to throw in if i have them in storage.
there are some scuffs and knicks in them, but overall are in good shape.
im not sure what else i have to go with this set, but will include everything i find for them.
this set also come with the inner door brackets, which you MUST install for these door panels to work.
150+ ALL SHIPPING!
OR....
i can sell both sets for 275+ ALL SHIPPING COSTS
i will have pics up this weekend after i gather everything in one spot. its all at my shop right now.
these are the 1st set of panels.
Attached Thumbnails BLACK GTA DELUXE DOOR PANELS! COMPLETE! TWO SETS!-mar21001-small-.jpg   BLACK GTA DELUXE DOOR PANELS! COMPLETE! TWO SETS!-mar21003-small-.jpg
Old Oct 23, 2008 | 07:22 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: BLACK GTA DELUXE DOOR PANELS! COMPLETE! TWO SETS!
Someone buy em !
Old Nov 1, 2008 | 06:09 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Interested-- PM sent.
Old Nov 1, 2008 | 08:14 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
here is the 1st set of panels that have been installed on my car, they are a complete set, minus the lil firebird emblem that goes in the door handle trim. i dont have a firebird, so i didnt install these pieces and have no idea where they are. this has the blanks for non power locks, a hard piece to find in itself. only thing that isnt in excellent shape is the ring around the upper bolt on the armrest. one has a crack and the other is missing the bottom. once its bolted to the panel, you can hardly see the piece thats missing. this IS the weakest link on the door panels. they have the strength of a ritz cracker.
the strips are NOT perfect, but they are very strait to most that i have seen.
i was a bad boy and dropped one, putting a slight crack in the pass side towards the front. its only cracked on the top. its not a complete break. i wiggled and wiggled it, seems pretty sturdy.
here are the nicks from shoes/boots/whatnot
this is the only spot on any of the carpet that is imperfect. the carpet is tight. seems one row of carpet decided to check out over the years. you could prolly hit it with a sharpie or a quick dab of spray die. its hardly noticeable, but i want buyer to be aware of any damage.
iv had these panels in my car since 2003 and are well taken car of. the only reason i removed them is i updated to 4th gen door panels to match my dash.
Old Nov 1, 2008 | 08:24 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
here is the 2nd set of panels. these arent as in good of shape as i thought.
id have to rate them a 6-10 now becuase the carpet is loose. not to the point where its horrible, but i would address this before installing them in my car.
pretty common on these panels. looks like the previous owner tried to repair these and used the wrong glue.
the panels were held tight when i removed them.
you can see here the loose carpet on the pass side.
the carpet just isnt as nice on this 2nd set.
the 1st set the carpet is beautiful. otherwise, its pretty std issue for a 20 year old panel.
this was broken when removed. the rest of the metal track is very sturdy and held tight to the door.
here is all the hardware. all bolts and brackets are included.
this set does NOT have lock tabs, the lil firebird emblem for the door handle trim, and some of the covers for the armrests screws were missing. i found some tan ones and dyed them to match. its a near perfect match. also they do not have the trim rings for around the front bolt for the armrest. its only cosmetic. if youve never seen them installed there you wouldnt know. they fell to pieces upon removal. crumbled like a cracker.
also notice on both panels, just towards the rear, behind the armrest, are two "soft spots"
they were like this when i got them, you can push your finger on it and its not hard like the rest of the cardboard. both panels are like this. its an area about the size of a nickel??? the leather is not loose, it appears to be the backing of the panel.
im going to lower the price on the 2nd panels to $100.00 FIRM.
they are not show pieces, but are still a hard to find. with a few bucks fixing or replacing the carpet they could be really nice.
Old Nov 1, 2008 | 01:43 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
PM Sent
Old Nov 9, 2008 | 09:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
SOLD!
thank you!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
