[MD] Lots of parts for sale
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
8 Accel 19lbs injectors with 5000 miles on them-$125
8 Stock 19lbs injectors with 120K on them-$30
Accel 300+ igniton part number 49321, has a brand new coil, digital rev limiter, all plug and play-$200
Accel plus 3 stage rev limiter, looks brand new, i bought it for $100 at a swap meet and never used it-$50
Stock throttle body, has an air foil and a new cover on top that has ws6 engraved into it,the clip for the tps is broken, and 2 bolts holding the iac housing are broken but it does not leak coolant -$30
2 165 ecm's one is missing the cover for the chip-$75 each
Slp cold air intake for speed density cars, but it can for for maf cars-$120
TPI fuel rail, has a holley adjustable fuel pressure regulator on it-$50
Aftermarket distributor i belive its made by procomp electronics-$50
Crane compu cam 2031 with lifters has 10k miles on it-$100
Comp magnum roller tip rockers, also has 10k miles on them -$75
BBK 58mm throttle body-$150 pending sale
if your interested in any of this let me know, thanks
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Re: Lots of parts for sale
which tb, i think the 58mm bbk is sold, i can get pictures of the stock one if that what your talking about
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
you got any pictures of those roller rockers, fuel rail and distributor.... pm me or email abailey79@hotmail.com
1992 Trans Am
May 10, 2023 07:19 PM
