lots of misc thirdgen stuff!
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
I have many many 82-92 (few 93-02) camaro and firebird parts from cars ive dissassembled over the years and its time to clean out the garage. including
many interior trim pieces
82-92 camaro fenders $50 each
82-92 firebird drivers side fender $50
85-92 camaro z28 hood with provisions for blisters or louvers (not included) great shape $75
pair of iroc hood louvers, missing tabs so ill let them both go for $40
hatch motors: 1 early style, and 2 92 style $45 each or 50 shipped
blower motors $20 each or 25 shipped
ac delete heater box $ 100 shipped
red lower console $40
manual trans shifter plates $55 shipped
lower trans shifter boots $25 shipped
crossmembers for 700r4 or t5 $25
driveshafts (both stock and aluminum) $40 for a steel shaft/$125 for a aluminum shaft
interior plastics in black and red
4th gen black/grey 4th gen seats. no significant damage, good bolsters, front and rear seats. No front tracks, but you would use your existing tracks from a 3rd or 4th gen as they are the same and are a direct bolt in. Only reason im selling is i bought a set of sparco buckets. Same reason im holding onto the tracks $250/set
clutch pedals for ls1 style t56 $50
89 camaro engine harness, and light harness. basically the complete harness for underhood all the way to the firewall and to the computer $60
87 iroc 305 carb auto ecm $40
89 iroc 305 tbi auto ecm $40
serpentine belt engine brackets $60
ac compressor for serpentine car in working order, no clutch noise $50
smog pump for serpentine car $30
ac condensor with lines for a serpentine car. car had a charge when removed $75
radiator $75
single electric fan assembly $75
camaro drivers side quarter panel complete and no rust $100
seat belt assemblys in black color
lots of under car plastic pieces for the front end
chin spoiler 85-90 z28/iroc/rs style $50
side rocker ground effects 85-90 style rs/z28/iroc $25/side 91-92 z28/rs $30/side
camaro rear bumper covers 85-90 style rs/z28/iroc $50 each 91-92 z28/rs style $60
set of used edelbrock valve covers $20 can have finish sandblasted for additional $10 for perimeter bolt heads
th350 trans mounted torque arm bracket $30
torque arm assemblys $20 for non g92 setup (have holes in center) $50 for g92 solid torque arm with a poly bushing $60
brake master cylinders $25 each
brake boosters $25 each
grid style taillight assemblies $20 each or 35/pr
early style coolant bottle (will work on all) like new (used for less than 200 miles) $20 or $30 shipped
ls1 exhaust manifolds $40
ls1 heads 853 casting with valves and springs, no retainers 30k miles $60
underdash covers and kick panels
low tension hood shocks (good for cowl hoods, or any aftermarket lighter hood) $50
good hatch shocks $40
horns $20 or 25 shipped
fan mounting brackets
tpi lower airboxes $30
fuel doors $10 each
clutch resevoir with hose to master $20
dash bezel covers
6 350tpi injectors $25
oem roller lifters with dogbones and spider $50
front license plate holder $15
rear trunk weatherstripping $20
third brake light assemblies
black sun visors in good shape for a hardtop car (will work in either) fabric not sagging, and they stayed in place in the car $40 or 45 shipped
taillight wiring harness $20
strut mounts $20
tbi/carb air cleaner with hose $30
used firestone firehawk sz50 ep 245/50/16 tire $25
automatic pedal assembly $30 or $40 shipped
ttop glass
wiper motors $25 or $35 shipped
93 z28 150 mph speedo cluster $60
big brake upgrade parts
98-02 front calipers $75 or $80 shipped
firebird/trans am dash map pocket good shape, doesnt hang open $40
2 gold dimpled style gta 16x8 wheels. good shape, no significant damage. Lightest factory thirdgen wheel, perfect for drag radials $125 can ship also
im sure
all pictures can be seen at this link 13 pages of photos
parts for sale pictures by randy87iroc - Photobucket
I am not a business, merely a thirdgen fanatic who has personally owned all of the cars these parts have came off of. I have accumulated these parts over the years and its time for them to go so i can have garage room. Im sure there are pieces not listed up there that i have or that i have pictures of. If you dont see it, just ask, alot of the small miniscule stuff is the stuff sometimes forgotten
if there is a shipped price, it is for the continetal US only
located on the southside of indianapolis for pickup, can meet or deliver for fuel compensation (reasonable distance), or can ship at buyers expense
email: streetracer420@hotmail.com or randyirocz@aol.com
ask for randy
thanks and have a great day
radiator $75
fuel doors $10 each
dash bezel covers
strut mounts $20
ttop glass
im sure
ask for randy
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Re: lots of misc thirdgen stuff!
If emailing please add your tgo screenname so I don't get anything confused
Thanks!!!!
Thanks!!!!
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 5, 2015 11:57 PM
NBrehm
Aug 5, 2015 07:57 PM
