[Sold] grannelli HIGH flow MAF
Old Aug 29, 2010 | 07:49 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
New unused. Have all original instructions, reciept, and box. This is the adjustable one. Replaces stock TPI MAF and they state 10-15rwhp. Advanced electronics I purchased it new for 300$. Im asking 200$ and 10$ to ship.
Performance You can Feel
The extra power you need when you need it: on the ramp acceleration, on demand passing, towing, through the hills or wherever. Granatelli Motor Sports performance mass airflow sensors reduce engine load and improve efficiency. This occurs by providing quicker and more accurate calibrations to changes in engine intake airflow, fuel and spark timing. In addition, the smooth design of our sensor's inlet tube improves airlfow capacity over OEM equipment by and industry leading 47%. The added performance is chassis dyno proven from 2000 rpm to the red line. Most importantly, the performance can be felt where it counts, in the seat of your pants. Granatelli Motor Sports performance mass airflow sensors are ideal for adding extra performance with none of the hassles. Ally you need are basic hand tools and 10 minutes of your time. Just follow the included step-by-step instructions and you'll enjoy 10-23 rear wheel horsepower in no time. Now that's performance, quick and easy!
How They Work
Mass air induction systems measure airflow systems measure airflow with an electronic "hot-wire" type mass airlfow sensor. The sensing element in the air intake provides an output voltage reading that is directly proportional to the amount of air that is entering the engine. This airlfow measurement reduces the calculations required to control fuel and ignition spark advance. Mass airlfow sensors can react quickly and accurately to sudden changes in airflow while improving overall vehicle performance and drivability.
Calibrated for Optimum Performance
Granatelli Motor Sports spends hundreds of hours testing and calibrating to optimize performance for your specific application. Each application is calibrated on our proprietary computerized flow bench. Then, each application is dyno tested and driven under a variety of real world tests using sophisticated air/fuel ratio monitors, exhaust gas temperature gauges and data logging computers. The result is optimum performance for YOUR specific application.
Finally, a replacement Mass Air Flow Sensor hat has HIGHER RELIABILITY than the original equipment unit. It has been PATENTED by Micro-Tech Automotive. This unit has up to 30% HIGHER AIR FLOW RATE than the original equipment unit and you don’t have to tear out the screens or grind down any parts inside! Our unit is the only unit available that features ADJUSTABLE CALIBRATION. If you have a highly modified engine, then this is what you have been waiting for! High lift cams, big valves and intake system changes that increase the volumetric efficiency of your engine create the need for an Air Flow Sensor that can be tuned to meet the needs that your combination requires. Up to 15 R.W. horsepower and 15 lb./ft. torque are possible depending on individual engine modifications and final calibration.
Old Jan 24, 2011 | 03:42 PM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: grannelli HIGH flow MAF
hi, do you still have the MAF?
Old Jan 24, 2011 | 08:54 PM
Car: 87 TA clone
yes, i have someone interested but if he doesnt come through then it goes to the next person, u interested?
Old Jan 25, 2011 | 07:50 AM
gcj280's Avatar
Car: 1987 Iroc Z
possibly, is the price negotiable any?
Old Jan 25, 2011 | 09:29 AM
Car: 87 TA clone
not really, the MAF has never been used and is a 300$ MAF, pulling 100$ of the price for it to just have been sitting around for a year is pretty good.
Old Jan 28, 2011 | 05:17 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
payment sent Thanks
Old Jan 28, 2011 | 05:19 PM
Car: 87 TA clone
Re: grannelli HIGH flow MAF SOLD
SOLD!
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
