[CO] Reprogramed tpi maf memcal
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This is for gtaman , The memcal started life as a ABUN= 1987 LB9 5.0L GAS 8 CYL MFI TPI With MD8 AUTO 4 SPD THM 700 R4. It was reprogramed to ARAP 1989 corvette L98 5.7L GAS 8 CYL MFI TPI With MD8 AUTO 4 SPD THM 700 R4 ( no 9th injector).
Vats delete, Egr delete code 32 removed, air pump disabled, cooling fans on at 200f and off at 185. $80 shipped
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
Re: Reprogramed tpi maf memcal
I saw the PM that was sent but am interested if no sell. I do have some ?'s that in case though...
I've got an '89 non-g92 iroc that's going to get a roller 350. Is this chip just plug and play?
Will I need to short the starter or some kind of wiring for the VATS delete?
Engine: Lb9
Transmission: M20
This ad is for gtaman . Please pm me and I might be able to assist .
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Just got it today, Brian! Thanks for all your help and expertise! I'll let you know how it works when i fire up the car probably next week.
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
