Garage clear out, misc parts ECM, dizzy, flywheel, oil cooler
Old May 19, 2013 | 12:49 PM
MarkF's Avatar
Please help me clear this stuff out I hate throwing third gen parts in the trash. whatever you want to pay is fine.
Door handle panels L&R, looks like for manual mirror (new)
2 Firebird/TA wheel center caps
Flywheel pre 87' 2 piece rear main
T-5 shifter stock
washer fluid reservoir with pump and wiring harness
door speaker box
stock jack
SOLD ---------------------------------------
Flywheel post 87' 1 piece rear main
89' 350 camshaft duration: 207 213 Lift: 415 430 Lobe Separation 117
first generation G-tech meter. Does 0-60 1/4 and HP single line LED type display ------ SOLD
ECM from an 86' TA Auto -------------------- SOLD
HEI Distributor from 89' 350 TPI -------------- SOLD
AC Delco 3 wire heated O2 sensor #25312179 (new in packaging) --- SOLD
85' rear view mirror
Locking gas cap with 2 keys (new)
Column security device
window guide (new)
Engine cylinder hone tool
T-5 crossmember
TPI Oil cooler sandwitch with hard lines
door hinge (new)
serpentine idler pulley (new) - NOT AVAILABLE, wrongly ID'd
Attached Thumbnails Garage clear out, misc parts ECM, dizzy, flywheel, oil cooler-img_2172.jpg   Garage clear out, misc parts ECM, dizzy, flywheel, oil cooler-img_2171.jpg
Old May 20, 2013 | 09:30 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: Garage clear out, misc parts ECM, dizzy, flywheel, oil cooler
How much for these to 71047?
ECM
window guide
Door Hinge
O2 Sensor
Old May 20, 2013 | 12:25 PM
MarkF's Avatar
Sorry those items are sold. I updated the list with current status
Old May 28, 2013 | 08:27 PM
KILLemALL's Avatar
Car: 77 Y82
Engine: W72
Transmission: Super T-10
Bump for a good seller!
Old Jun 25, 2013 | 03:40 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Old post, but do you still have the 1 piece flywheel? If so what do you want for it and shipping to 55379? Also, I am assuming it will need to be resurfaced.
Old Jun 26, 2013 | 10:21 PM
MarkF's Avatar
Yup still got it. Resurfacing is a personal choice I feel, I've never done it and this flywheel hasn't ever been cut so plenty of meat if you need to cut it down.
USPS is giving me $26 to your zip but I think I might be able to barely stuff it into a medium flat rate box which would bring that down to $13. How about $15 for the flywheel itself? And I'll get back to you on fitting in that flat rate.
Old Jun 28, 2013 | 01:12 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Could you check the medium rate box, just for the heck of it? It would be nice to save on shipping, but completely understand if it does not fit. Let me know and we can go from there.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
Street Lethal
Aug 12, 2015 11:33 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
