Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
Old 02-25-2008, 11:17 PM
  #51
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Re: Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
Could you please pm or email me prices for you bracket. Also kit prices. My 87 Z28 came with limited slip & 3.43's.
Old 02-25-2008, 11:55 PM
  #52
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm working on PMs tonight so I should be able to make some good progress and will get to you soon.
Ed
Old 02-27-2008, 02:59 AM
  #53
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Originally Posted by ebmiller88
Kevin, I'll reply shortly. As for the lines, I include them in all my kits but if you buy, get lines for a 4 wheel disc car as that's the 5 piece line set.
Ed
i have a 92 ws6 ta convert with rear drums and i want rear disc
so is this the easy and cheapest way to do that?
also can i get a price on a kit (with everything i need that i can't reused on my car now) thanks
Old 02-28-2008, 01:39 AM
  #54
ebmiller88's Avatar
Did I get back to you? If I did I didn't track it in my sent folder...LMK
Old 02-28-2008, 02:02 AM
  #55
ebmiller88's Avatar
If you want to keep your current rearend gear ratio, this is the best solution. If you want to upgrade gears as well as brakes I'd look into getting a whole rear but good third gen rears along with PBR disc brakes are getting impossible to find.
I'll PM you on kit info.
Ed
Old 02-28-2008, 11:30 AM
  #56
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Ed
what is PBR and if i went with a whole rear upgrade what years should i look at
Old 02-29-2008, 01:08 AM
  #57
ebmiller88's Avatar
PBR makes a load of calipers for many cars:
http://www.pbrbrakes.com/
With these plates you can fit the good rear discs from '89-97. You can also swap to '98-02 LS1 rears but they're a bit different and won't work with these plates.
Ed
Old 02-29-2008, 02:34 AM
  #58
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Ed
How much for kit
Old 03-03-2008, 08:19 PM
  #59
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
Transmission: 200-4r
Axle/Gears: 3.42 GN Posi
Can I just get these backing plates from an 89-97 f-body at a junkyard? I thought 89-97 had the rectangle flange instead of square like ls1?
Old 03-04-2008, 02:41 PM
  #60
ebmiller88's Avatar
Not the drum rears, just the disc rears. These are not stock plates.
Ed
Old 03-04-2008, 08:39 PM
  #61
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
so stock backing plates from a disc rear will not work on my rectangle flange El Camino?
Old 03-06-2008, 03:52 PM
  #62
DREGSZ's Avatar
Long post lost.
11.6 or 12" rear rotors are plenty big.
I used to lock up the rear PBRs on stock discs every lap when racing, but 12" or 13" fronts w PBRs or C5 calipers is the way to go!!
A good track or combo pad will make a world of difference in brake performance.
I won't ever go back to stock or greenstuff type pads even for street use in my F Body
hit up Jeff at speedtoys,com for pad applications and discounts, (I get the same brodeal as you, tell him I referred you.
Third Gen Race Pics:
http://rides.webshots.com/album/157758534cwBEim
Evan
Old 03-08-2008, 04:03 AM
  #63
ebmiller88's Avatar
They may be slightly off but I think they will. Once I get the rear out of my '70 RS I'll have plates for some of the older cars as well.
Ed
Old 03-10-2008, 12:19 PM
  #64
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
I'm interested in converting my drum brakes in the back to disks...Can you PM me prices? Thanks!
Old 03-11-2008, 09:48 AM
  #65
85camarojunkie's Avatar
Car: Camaro coupe
EBMILLER can you PM me or email me i have your brackets for the 9bolt off.
Old 03-11-2008, 11:30 AM
  #66
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
In case I can't make stock plates work, can you PM me prices as well?
Old 03-11-2008, 01:25 PM
  #67
z1colt45's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Please PM me prices
Old 03-12-2008, 10:49 PM
  #68
ebmiller88's Avatar
PMs sent..thanks all.
Ed
Old 03-12-2008, 11:48 PM
  #69
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
hate to be a bother and add to your never ending list of PMs but could you send me some price info if i wanted to do a full kit for my 89 RS? like brakets rotors calipers lines brake cables etc???
Old 03-15-2008, 02:23 PM
  #70
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
Ed
hey thanks, I got the pm, bua couple of questions:
can I get PBR (J65?) brakes from a v6, or is it just a certain model?
oh, and will the backing plates for 9 and 10 bolt be the same? or are they all 10 bolt that have pbrs?
thanks again for sharing your knowledge.
Old 03-15-2008, 05:11 PM
  #71
ebmiller88's Avatar
V6 cars didn't get rear discs, only the Z28s/ higher end models got them.
9 and 10 bolt disc plates are dimentionally the same but will have a different bolt pattern, I have plates for both. All drum plates will be the same either way. The '89 9 bolts were the only 9 bolts to get PBRs, all rear discs from '89-92 got the PBRs, both 9 and 10 bolt.
Ed
Old 03-15-2008, 09:05 PM
  #72
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
one more question, does it make a difference whether the caliper is behind or in front of the rotor? I was wondering if I could use these plates on opposite sides putting the caliper in front in case I have shock clearance issues as with LS1 brakes.
Old 03-15-2008, 10:01 PM
  #73
ebmiller88's Avatar
yes you can.
Ed
Old 03-17-2008, 02:03 AM
  #74
ttchevyhd's Avatar
Car: 92 RS
Axle/Gears: 3:73 Posi
Ed could I get a price on yor plates too. Will they work with the rotors and calipers off the 93 - 97 on the third gen camaro? Also which e-brake cables do you have to get 82-92 or 93 - 97? I have a friend that has a complete 94 rear I could get for brake parts.
Old 03-17-2008, 04:25 AM
  #75
ebmiller88's Avatar
PM sent..the '93-97 rear discs will bolt right up. You will need to use 3rd gen brake cables for your car and rear discs.
Ed
Old 03-18-2008, 09:14 PM
  #76
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
any info on that kit i asked about?
Old 03-18-2008, 09:47 PM
  #77
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
Well, after some research it appears I will have shock interference with my g-body. I need to find a relocation bracket if I use this setup. I'll post back in a few days.
Old 03-20-2008, 03:51 PM
  #78
ebmiller88's Avatar
Do you have staggerd shocks or something? Can you use two same side calipers, depending on where your interference is?
Ed
PMd you.
Ed
Old 03-30-2008, 06:36 PM
  #79
wht96's Avatar
PM SENT
Old 05-03-2008, 11:04 AM
  #80
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
I was ready to go ahead and order these, but noticed something else. how does this kit accomodate the step in the mounting flange? wouldn't the conversion plate bend when tightened down?
Old 05-06-2008, 05:59 AM
  #81
ebmiller88's Avatar
Washers are supplied to fill in that gap, problem solved. Thanks, Ed.
Old 05-06-2008, 09:14 AM
  #82
14ZROAD's Avatar
Car: 91 Z28
Transmission: Automatic
Axle/Gears: 3:42
Ed,
Could you please PM me some prices for some front kits and rear kits and possibly what all options I have. I have a 92 RS ( stock as of now).
Thanks in advance, Z
Old 05-06-2008, 09:50 AM
  #83
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
alright, I'll get a check in the mail. thanks
Old 05-06-2008, 04:15 PM
  #84
nancygrl2002's Avatar
Car: 1995 Camaro
Engine: V6
Transmission: 5 Speed
Hi Ed....
I know the thread is for 1LE/LT1. I have a 1995 Camaro V6 3.4L. I was wondering if there was any rear disc conversions for my Camaro?
PM sent Ed.......
Thanks,
Nancy
Old 05-06-2008, 06:49 PM
  #85
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
PM sent Ed.
Old 05-07-2008, 10:40 PM
  #86
ebmiller88's Avatar
Originally Posted by nancygrl2002
Hi Ed....
PM sent Ed.......
Thanks,
Nancy
Yes I do, I'll PM you and the others as well...thanks!
Ed
Old 05-07-2008, 11:49 PM
  #87
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
What gears do you currently have? I don't want to dissuade you from anything that Ed has to offer, but you might consider looking for a complete 4th gen LT1 rear (3.23 for some autos or 3.42 for some manual transmissions) and grab the proportioning valve and e-brake cables off the car as well. This would be a direct swap and you'd get the added benefit of the possible higher gear ratio. Or sell your car and buy an TPI/LT1/LS1 Just my
Old 05-08-2008, 08:07 PM
  #88
ebmiller88's Avatar
A agree..a rearend swap may be the ticket for you if you can find one close. I just sold a 3.23 4th gen rear and I still have a 2.73 posi disc rear but I'll assume you'll want better gearing than that one.
Ed
Old 05-12-2008, 03:22 PM
  #89
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Order sent via PayPal. Check PM for details. Thanks
Old 05-13-2008, 02:31 AM
  #90
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Ed
how much for the 2.73 posi disc rear
Old 05-14-2008, 04:33 AM
  #91
ebmiller88's Avatar
I have a pending local sale but if it falls through I'll get back to you via PM.
Ed
Old 05-19-2008, 11:25 AM
  #92
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I just PMed you.
I scored a 3.23 Posi Drum rear end for my Firebird, and this looks to be the ticket for rear discs.
Thanks man!
Old 05-26-2008, 12:02 PM
  #93
ebmiller88's Avatar
Good deal. Since drum rears are very cheap finding one with good gears and posis will be the way to go.
Ed
Old 06-24-2008, 12:11 AM
  #94
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Hi, I got a 90 RS with rear drums, just want to upgrade them at this time, can I get a price quote? thanks.
Old 07-26-2008, 11:28 AM
  #95
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
ok heres my question. Im swapping from a 9bolt 3.27 rear with the non-PBR Brakes, to a 4th gen LT1 rear, do I need to change the proportioning valve? also can I get a price on a parking brake cable?
Old 08-05-2008, 03:45 PM
  #96
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
Will the plate that the caliper bolts to from an lt1 bolt to an82-88 rear discs axle
Old 08-11-2008, 02:17 PM
  #97
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
PM sent for pricing. Thanks!
Old 08-15-2008, 12:33 AM
  #98
slycer2002's Avatar
I actually have a 4th Gen F-body, a 93 Camaro V6, but this should still work, right? I'm not looking to upgrade the gears or put in posi or anything, just yet. Its my wife's car, and she wants rear disc. Anyway, I was wondering if you could PM me prices for just the bracket and also for the whole kit. Thanks!
Old 08-15-2008, 11:36 AM
  #99
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Ed, relatively new to the board but I like what I've seen thus far, if possible could you shoot me a pm w/pricing info on the complete kit for a 91 rs w/rear drums (ttop if it matters) not sure on the gearing ratio yet.
Old 08-17-2008, 01:17 PM
  #100
ebmiller88's Avatar
PM sent.
Ed
PM sent.
Ed
Quick Reply: Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
