Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
Old 05-25-2009, 04:46 PM
  #151
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
I'll PM with replies.
Ed
Old 05-28-2009, 08:58 PM
  #152
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, can you post a price and a list of this kit?..also .where can we get in touch with your company?
Old 05-28-2009, 11:06 PM
  #153
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Just send him a PM. Ed's a good guy he'll take care of you.
Old 05-29-2009, 11:05 AM
  #154
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
mooch1, you may have to wait A WHILE. I messaged him back in December and am still waiting for a response. Now, I don't NEED brakes right now, but would like to get everything situated ahead of time, so when the day comes I can get everything right away.
Old 05-29-2009, 11:13 AM
  #155
luke4907's Avatar
Engine: TPI350
that one probably got lost with all his other PMs... I'd send him another one. And he told me he's very busy right now when I PMed him last week or so. seems some business ARE recession-proof
Old 05-31-2009, 06:17 PM
  #156
mooch1's Avatar
Transmission: T5 WC
hey guys thanks. i just would like to know the price and availability of these conversion parts...i have drums now and they work ok...but this conversion kit seems easy to install ..do you know what kind of discs and calipers needed?..and from what vehicle they come from?.. i would like to have this kit for the fall and install this during the winter nice and easy in my garage on my spare time,,,i'll wait and see if he responds...no rush......thanks again././.
Old 06-01-2009, 04:09 AM
  #157
luke4907's Avatar
Engine: TPI350
First, I just wanna say Ed correct me if I'm wrong on any of this.
This is for the 89?-92 J65 rear disc setup. 11.65" rotors, single piston calipers. They were also available on 93-97 4thgen cars, although slightly different calipers and e-brake setup IIRC. You can find cheap white box rotors, but the calipers are pretty expensive (unless you find some in a junkyard). You'll probably also need a proportioning valve (stock or Wilwood adjustable) since you have drum rear.
I'm sure he'll get back to you... patience
Old 06-01-2009, 07:48 AM
  #158
85camarojunkie's Avatar
Car: Camaro coupe
www.Flynbye.com
lot or your questions can be asnwered on his webpage.
Old 06-01-2009, 10:57 AM
  #159
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
^^Hell yeah, thanks. Is that Ed's site?
Old 06-01-2009, 11:26 AM
  #160
Car: Camaro coupe
Yup. Dang good deals. Im running his caliper brakets on my 10bolt no probs so far, doubt i will either. They look good. May be for sale soon looking for a 4th gen rear. I may sell my brackets with pads, rotors, calipers, cables.
Old 06-17-2009, 10:39 AM
  #161
zrag's Avatar
Car: 1991 z 28
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3:23
Hello,
are you still selling these conversion kits?
please call me at 952-261-9909 thanks, steve
Old 06-17-2009, 07:55 PM
  #162
ebmiller88's Avatar
PM sent with my info..thanks!
Ed
Old 06-17-2009, 07:58 PM
  #163
ebmiller88's Avatar
I'm a bit busy, yes, to say the least. I caught up with all current PMs yesterday, e-mail is another story.. Best bet is to call if you want to discuss application and specific questions.
FYI, the LS1 conversion cables should be coming in a week or so. I finally got to work on my own car and moved it in order to fix a few things and do a rearend swap/LS1 disc upgrade. Pics and info to follow in another thread.
Ed
Old 06-17-2009, 08:01 PM
  #164
ebmiller88's Avatar
Yes, '89-97 calipers will work with them. The calipers are essentially the same during these years. I made brackets to use the stock 11.6" size, larger 12" rotors, and full 13" rotors should you want to go that large. I'd install either a disc prop or an adj. valve, yes.
Ed
Old 06-17-2009, 10:21 PM
  #165
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Hey Ed, out of curiosity is that an off-the-shelf 12" rotor ?
Old 06-18-2009, 08:52 PM
  #166
ebmiller88's Avatar
Yes, C4 'Vette rear.
Ed
Old 06-19-2009, 09:45 AM
  #167
trumps2000's Avatar
Car: 1985 Z28
Hey Ed, one more question, I have the stock Z28 rims will the PBRs fit? What about with the 12" rotor?
Old 06-22-2009, 11:34 PM
  #168
ebmiller88's Avatar
They should without issue.
Ed
Old 07-05-2009, 09:20 PM
  #169
sergio's Avatar
Car: 91 T-am convertible
Engine: 5.0 TPI
Transmission: 5 speed manual
Hi Ed,
This is great information.
I have a 91 TA, unfortunatly in came with rear drum brakes. I have purchased a complete set of disc brakes from a 92 Z28 (calipers, 11.6" disc, all the hard lines and parking lines). From reading your thread it appears I am only missing the adapter bracket. Are you still selling them? how much?
Old 07-20-2009, 02:18 AM
  #170
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
PM'd
Old 07-27-2009, 07:11 PM
  #171
Car: Camaro coupe
Might i ad the parts i have bought off of ed very high queality. With that said i just bought a 4th gen rear with the discs so mine will be for sale with calipers and pads and rotors. Actuall the whole rear end but i guess i can stick that in the for sale ads haha. Thanks ED. willl be looking at big brakes for the LT1 rear soon.
Old 07-28-2009, 07:20 PM
  #172
ebmiller88's Avatar
Originally Posted by sergio
Hi Ed,
Yes, these brackets are all you'd need. Please note that since you got 3rd gen rear discs you'll have to either turn your drum axles down a bit or just get new rotors from a 4th gen so you won't have to turn the rotors. Drum axles (3rd gen) are larger in OD than disc ones.
Ed
Old 07-28-2009, 07:21 PM
  #173
ebmiller88's Avatar
Glad you liked them.
Ed
Old 07-28-2009, 09:21 PM
  #174
Car: Camaro coupe
Love em. Sad to sell them. Id like to hold them for future project. But Ill be hitting you up for big brakes soon. got to get the LT1 in first (dash, motor, trans and rear from 95). DO you know anyone that is interested in these before i slap them on the for sale?
Old 08-09-2009, 10:26 PM
  #175
dro561's Avatar
Car: 91 Camaro RS
Engine: Currently 3.1L v6 building 350
hey ed i have disk/drum with a 10 bolt rear and 3.23s and i want to do this conversion please pm me for the price and i would like to know if you can do the whole set up for me lines, proportioning valve, e-brake etc. thanks
Old 08-16-2009, 06:46 PM
  #176
Chrome on Rust's Avatar
Car: 89 RS
Engine: 305 TBI
Would like a Pm on a price for the brackets Plz
Also, if i were to go in to auto zone or where ever, and needed to replace a caliper, rotor, or pads. what kind of car would i tell them i need the parts for
Oh yea sorry i have an 89 Rs 9 bolt
Old 08-16-2009, 06:54 PM
  #177
Car: 89 RS
Engine: 305 TBI
If i could get a price on a proportiong valave and the ebrake calbes to plz and thanks
89, rs, 9 bolt, 305, tbi
Old 12-13-2009, 08:25 PM
  #178
1991 Z28's Avatar
Car: 1991 Camaro Z28
Axle/Gears: LS1 3.23
ed,
I have a 91 z28 with drums and I wanted to know how much for your kit? Also, do you have a kit for bigger front brakes? Pls email me at allenpasion@gmail.com
Old 12-14-2009, 12:35 AM
  #179
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Originally Posted by 1991 Z28
ed,
Ed's store
http://www.flynbye.com/
Old 12-19-2009, 01:29 PM
  #180
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: 5.7 TPI - LS1 Forged by LME
Transmission: 700r4 - 4L60E
Axle/Gears: 3.23 - 3.73
So let me make sure I understand this. Which style rotor might give you trouble with this swap due to axle flange size, The old looking one on the right?? or the new looking one on the left??
Old 12-19-2009, 02:18 PM
  #181
iceinespana's Avatar
Car: 1991 Z28 Camaro Convertible
Engine: LB9, 5.0 TPI
Could you please send cost and everything your kit comes with to camarozzconv@yahoo.com. I would like to do this conversion to my 1991 Z28 Convertible.
John
Old 12-19-2009, 06:18 PM
  #182
mooch1's Avatar
Transmission: T5 WC
if you have a drum rear like i have ,,you need the 1995 type rear rotors ,,,this will allow you to install them on your axle flange with no hassle..it is the old disc in this pic..notice the center of the old disc...hope it helps..
Old 12-20-2009, 07:40 AM
  #183
Thanks for the reply. You are correct on my vert it has rear drums. But I am looking for the whole kit. The rear discs are easy enough but the rest of the mounting hardware is what I'm really looking for. I would like to know what the price of the kit is and what it consists of.
Old 12-20-2009, 05:54 PM
  #184
mooch1's Avatar
Transmission: T5 WC
hi , you need the calipers (try ebay) or get re-built ones & that's fine,,the pads and discs you can get anywhere as long as you get pads from 89-92 for pbr calipers, actually these pads also fit on rear 93-97 rear camaro and firebird calipers since they use pbr calipers as well....as for the discs , there are 2 types of 11.5 discs out there ,,ed says if you can't fit the rear 89-92 rear discs on you drum axle flange ,,then get 93-97 rear discs,,,they will fit on your drum axle flange without any problems....( i got new 1995 ones) then you can get the brackets from ed miller..these are from flynbuy performance,,i paid $85 for them and these will bolt to your drum axle flange with no hassles...very easy...i recommend you get new L/R caliper rubber hoses and also the rubber hose that is on the diff that splits to the left and right calipers (everybody forgets to change that one),,then depending on your budget , you should either get shaped steel brake lines ,,or just replace them with new ones from the rubber hose that splits to the calipers hoses left right...i also changed the prop valve and put one from a 1989 gta with 4 wheel discs,,,this is very important because the pressure for disc/drums and 4 wheel discs isn't the same ...then bleed everything and try it out...you should get also the e-brake cables so your e-brake is functional ...ed has all these parts and also the whole kits available if you don't want to buy items piece by piece...i took my time and bought some stuff here and there over the summer and then got the brackets ,,it depends on you and how much you wan't to spend on your car...you might have to use shims or spacers for the caliper brackets if they rub a little ,,after you bleed everything just try it out and see...most times it should be fine ,,,i hope this helps and good luck ,,let us know what happens.
Old 12-21-2009, 01:52 PM
  #185
jazzdadss's Avatar
Car: 1989 IROC LSX
I'm stuck for now. Ordered the kit last night, Hopefully it wont take long to get here. I am looking foward to getting the Iroc back on the ground. New calipers and rotors ready to go.
Old 12-21-2009, 03:07 PM
  #186
ebmiller88's Avatar
Sorry for the delay in responses, I'll be catching up on e-mail and PMs over the next week.
Have a Merry Christmas!
Ed
Old 12-29-2009, 09:13 AM
  #187
jazzdadss's Avatar
Car: 1989 IROC LSX
Thanks Mr. Miller, Looking foward to getting this thing on the ground.
I do have a question for this conversion? I see that no Dust sheilds are used, Has this ever been a problem for anyone? ( rain and dirt affecting braking ) Just Qurrious.
Old 12-31-2009, 08:58 AM
  #188
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
I bought this kit as well as the front end c5 kit from Ed. I just got the stuff in the mail, got the front end done, but this rear is a bear. I got the axles out and everything, I am now just trying to get the fluid cylinder off as well as the monster bolt. I wish I had the rear end off the car. Anywho, I am having a buddy come over today and we will see what we got. Overall though, very easy upgrade. I would recommend buying from Ed anytime. Once I am done, I will post a new thread.
Old 12-31-2009, 02:36 PM
  #189
ebmiller88's Avatar
No, the newer plates and even some of the '89-92 plates have them removed. You'll be fine.
Ed
Old 12-31-2009, 05:55 PM
  #190
jazzdadss's Avatar
Car: 1989 IROC LSX
Hey Ed. When do you think I might expect the kit. I know with the holidays and all youv'e been busy, just anxious.
Old 01-05-2010, 07:45 AM
  #191
jazzdadss's Avatar
Car: 1989 IROC LSX
Bump.
Old 01-05-2010, 07:49 AM
  #192
mooch1's Avatar
Transmission: T5 WC
same here, i did this this swap and it was quite easier than i imagined...ed is a good guy and was very helpful...his back plates are really good and strong and bolt right on ....i hope it goes as good for you as it did for me....
Old 01-06-2010, 01:46 PM
  #193
jazzdadss's Avatar
Car: 1989 IROC LSX
Thanks ED, Good luck to all getting anything done this weekend!!!! BRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!
Old 01-07-2010, 06:07 PM
  #194
Car: 1991 Camaro RS
Ya, I now got the backing plates on and the rear end put back together. The only thing left is running the axel hard lines and the e brake cables. I stoped working on her now becuase I will have to splice in a new line becuase where the main line goes into the splitter wont come off and is twisting the whole line off. I would have done it but its been really cold here lately and I have no heater in the garage. Soon as it warms up I will go get a line and flare kit to fix her. I am just glad I am past the tough part.
Old 04-16-2010, 10:36 PM
  #195
sergio's Avatar
Engine: 5.0 TPI
Ed,
Great thread, I am doing the exact same thing you outlined. I am in need of the adapter brackets and the proportioning valve.
Do you offer both?
Old 04-17-2010, 06:24 AM
  #196
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ed,
Do you offer both?
I believe he does. You might check his site for more info:
JamesC
Old 04-17-2010, 08:08 AM
  #197
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Keeping an eye on this.
Tony.
Old 09-09-2010, 03:09 PM
  #198
houstonvett's Avatar
JamesC
Is Ed still selling these pieces? Left a few Emails at the site with nothing back. I would like to get a set of these brackets if still available. TIA.
Old 09-10-2010, 08:26 AM
  #199
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
good luck. He PM'ed me saying he was going to call me 3 days ago because he had the day off. He never called me, or responded to a 3rd voicemail I left him 2 days ago. I've been trying to get ahold of him for 4-5 months now.
Old 09-17-2010, 10:20 PM
  #200
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
He's STILL on da' lam?! Hope nothing bad has happened.
Quick Reply: Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes
