Cheap Proportioning Valve Upgrade
#151
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: Cheap Proportioning Valve Upgrade
@arod231 thanks. ill have to try this out too. cuz my brakes take forever to stop haha
#153
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Hi
Anybody who have the spring 1NCR5 to spare,i have tried to order them but it is totally impossible to get them over to Europe from the companies in US.
Hopefully one of you fellow 3rd gens can help me out i will pay through Paypal,i just got my LS1 brakeupgrade from Scott and it would be great to have my discs in the back to bite a bit better also
Best regards Mats
Best regards Mats
#154
Engine: 2.8L V6
@badcam70 I just got a pack of both. Id be willing to send you them if you pay for shipping. Im not sure what company id be able to use though... would you want one of each??
#155
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
#157
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
If anyone is interested, i have 3 or 4 1NCR5 springs.
#158
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I got 2 left 5 buck plus shipping pay pay pal brioneschevybelair and sent a address
#159
I've got a 4 pack of 1NCF2 springs left. First person to quote me can have them for free. I'll even pay for shipping. My only requirement is that they take 1 spring and return the favor to someone else here until there are no more left. If i don't see you on here later that's bad karma! US only, please.
Also - Does anyone have a 1NCR5 spring?
#162
#163
PM sent to 84z4me. As soon as I get the springs, tag you're it.
Karma? More like my duty as a Christian, but that's another discussion.
#165
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Anyone have the stiffer springs? I have a pack of 5 of the mcmaster version of the 19lbs springs that I havnt even used since this thread started (sorry for everyone who pmed me months and months ago about it) Im willing to take a stiffer spring and send out my springs for dirt cheap. let me know
#166
If you're interested in the 1NCF2 springs - talk to the people above - they're all in line to getting free ones and there should still be 1 or 2 more left.
#168
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
I have extra heavy duty spring from my up grade, they come 5 to a pack
If you need one let me know I will mail you one
#169
don't need em, all you need is one
#170
Hmmm. Experiencing violent axle hop at heavy braking at higher speed. I may be swapping my 22lb spring out and going back to the stock one to see if this cures the axle hop.
#171
I test mine at slow speeds and it felt like night and day but I didn't try it 60 are 50mph I hope the problem is not the spring let us all know thanks
#173
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hello all, I noticed that this thread is still going on and every here and there I get a message asking if I still have some of the springs. I don't recommend this modification very much. I notice it works for some and not others and in my case, did not work for me.
I got to pluming and threading my brake lines and got it done the right way, the adjustable brake regulator is the safest way to go.
Anyways here is a conversation I had with geoffz28 a while back:
Hmm. That kinda makes me have second thoughts. Let me think about this one... I think the adj valve is the best way to go though for sure. Im kinda leaning towards that after your story there, plus I really dont want to deal with flynbye for a 1le valve... Any idea what # spring the one you put in there was that you were finally able to lock the rears?
Well... no the springs from grainger never fixed the problem with my rear brakes working after doing the same swap you did....
I still have 2 springs left I beleive... its always worth a try but after my attempt I wouldnt recommend it for anyone.
I can tell you what did "fix" the problem though.
I went to orchard supply and purchased a really heavy duty spring and threw it in the prop. valve.
NOW the rears lock before the fronts do... :/
(I was street racing the other day and spun my car out 360 deg. because the rears locked before the fronts did. luckily I only ended up in a flat dirt field...)
So... You could try experimenting until you get the correct spring that locks your rears right after the fronts lock or you could do what I'm going to do and purchase an adjustable combo valve which I NOW see as the best and safest way to go lol.[/quote]
#174
Car: 84 z
Engine: 383
Transmission: 700r-4
Axle/Gears: 2.77 9 bolt
Got 2 1NCF2 springs in the mail courtesy of 92-Formula via 3windcoupe. Thanks guys, now I just need a name and address of the next person who wants one to ship it to.
#176
Car: 84 z
Engine: 383
#179
Car: 1988 iroc
Engine: 350 30 over
I have one but its in a proportion valve that I never used, I brought a used one thinking it was going to be a pain to put in
#180
Just dropped $25 at grainger for the 19lb spring - need it ASAP. I will post a comparison of the 19lb to the 22lber. My opinion is the 22lb is a bit too much. Its not bad at all - the brakes themselves feel great at normal to moderate braking. But if you're doing any sort of track days/events I feel its a bit overkill - you'll roast the rears and get the occasional axle hop. Also very easy to get yourself into a spin when the rears engage that quickly. Hopefully the 19lb steps it down a bit.
I'll have 4 19lbs springs after this. If anyone wants the whole pack of 4 i can ship it out quick - a reasonable donation would be appreciated. :P
#181
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
What is the stock spring rate for the PBR equipped cars? Are the 19's you have any better? I noticed in the first post he was talking about 30's. That's quite a difference from 19's.
#182
Stock spring rate is something like 10 from what I recall. I think there are only two other options mentioned in here - 22lb and 19. I've got some 19s coming in on Monday - but veaceonee already claimed them. Talk to him and see if he can send the remaining 3 out.
#183
Car: 87' IROC
http://www.summitracing.com/parts/wil-260-8419
I love tinkering as well, but for $40 why bother with trial and error on different springs?
#185
No offense. But you have now probably spent enough where you could have just done it correctly and installed an adjustable prop valve and tuned it perfectly.
#191
Sure you got all the air out of the lines? Both springs locked up the rear tires with enough pedal pressure for me. I also have ls1 calipers up front and factory discs in the rear.
#193
#194
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
#195
PM me yr addr and I'll drop one in the mail to you.
Would like to know if it works for you as it did not for me. I've got to do some basic rear brake test to see if maybe my calipers are siezed but when I put in new pads the c-clamp pushed the piston back in no prob. Maybe it's not coming back out...
#196
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
#197
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
#198
Car: 88 GTA Notchback
Axle/Gears: don't know
I did this mod. Can't tell if it actually worked or not. Went to bleed the rear brakes, nothing but air. What I can say is my car stops a WHOLE lot better now.
#199
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
It's helpful and much appreciated if people can add this info to their post so that we can track the part #/spring rate and the results-thanks!
