[MO] Z03 Z28 Purple Haze convertible T56 LT1 swapped
Engine: Cammed 6.0L LSX
Original Purple Haze with silver stripe package Z28 with the Z03 option code. This car was literally in pieces when my father took ownership with the entire interior uninstalled from the vehicle. It was given a $6,500 show quality base / clear paint job with one-off custom hand painted stripes that look like brushed aluminum. The odometer reads 74,xxx miles.
The LT1 block and transmission were pulled from a 1996 Camaro SS. The heads and intake were ported but not bench flow tested. It was also given a pretty aggressive cam, with I believe a 109 LSA. I will try to locate the camshaft numbers, but the car was tuned by Performance by Joe in St Louis, MO. It has headers and a 3" exhaust system ending with a 2OTL (2 on the left) catback system. Heat and a/c work properly.
The rear axle is a 10 bolt from a 4th generation car with either 3.90 or 4.10 gears, can't recall off the top of my head. 4 wheel disc brakes obviously.
The car is in excellent condition inside and out. The doors shut smoothly like it was brand new, you can tell the body has been well cared for. MANY new GM parts were put on this car when we put it together, from door switches to the plastic cover for the gauge cluster, to door trim, etc. This is one you have to see in person to appreciate just how much time and effort went into the car after it was disassembled.
Asking price is $13,000. Call Dave at 314-304-2346 to schedule an appointment to view it. Location is ZIP code 63303.
Engine: 4++,350 & 305 CIs
Re: Z03 Z28 Purple Haze convertible T56 LT1 swapped
What a great car, can't believe you are letting this one go as well!!
They're going to keep the '71 Stingray
Bump
Bump
Lowered price
Streetstuff
Interior Parts Wanted
04-29-2016 07:22 PM
