1990 camaro enterior lights not working when door opens
Old 03-07-2010, 10:44 AM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
please help if you can no power going to the door switch when the door opens and the rear view mirror light doesnt light up .The power is going to the rear view mirror to turn on with the headlight switch but it dont light up when the door opens like it shoud fuses are good and when i put a test light to the tan wire no power or the white no power Help .This is a convertible any idead im stumped
Old 03-10-2010, 05:07 PM
My86'stitsRout's Avatar
Car: 65 SS Impala,86vertZ28,88vertIrocZ
Engine: Stock 305 TPI
Transmission: 700R4 Automatic
Axle/Gears: Stock
Re: 1990 camaro enterior lights not working when door opens
I would say check your grounds, both up top and the one coming from the door switch.
Old 03-11-2010, 10:59 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Make sure the switch in the door jam is actually pushing in and out like it is supposed to. I know my wife had the same problem with her IROC-Z, except the lights would come on when the passenger door was opened, but not the driver side door. The reason was that the switch in the driver side door jam was getting stuck and wouldn't push out when the door was opened.
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Jae992
08-27-2015 09:07 AM
Omega
08-10-2015 12:46 PM
Quick Reply: 1990 camaro enterior lights not working when door opens
