Camaro convertible spoiler
Old 01-01-2017, 09:46 PM
Gr89RS's Avatar
Car: '02 Z06
Anyone know how the side trim peice on the convertible spoiler is attached to the car? Adhesive or screws? See attached picture. Thanks!
Old 01-02-2017, 05:31 AM
LUVBOWTIE's Avatar
Car: 1991 CAMARO Z28 VERT
Engine: LS2
Transmission: MAGNUM T56
Axle/Gears: STOCK 7.5/3.73
Re: Camaro convertible spoiler
ON MY 1990 VERT, BOTH SIDE PIECE WHERE HELD ON WITH SEVERAL SCREWS ON THE INSIDE AND THE SOME DOUBLE-SIDED TAPE ON THE SIDES.
STILL NOT SURE IF THIS WAS A USE ON DEMAND OR IF THERE WAS A SET PROTO CALL AS THESE CAR A STARTED OUT AS COUPES
Old 01-02-2017, 08:08 PM
Gr89RS's Avatar
Car: '02 Z06
You remember how to get to the screws?​​​​​​​
Old 01-07-2017, 12:50 PM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
My 88 has screws that are visible when the trunk or tonneau cover is open. Then double sided tape along the outside where it meets the rear quarter.
It was the same way on the 92 when I pulled those for spares.
Old 01-07-2017, 04:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Mine was held on by two screws by the tail light and then it was all adhesive silicone from a tube.
