help me find this part!!!!
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok i got rid of a pipe that i thought was pointless but now i see that i needed it. the hardline pipe that goes from the heater core to the waterpump and radiator. its a metal hardline that does passenger side of the engine bay.
anyone?
anyone?
Car: 85 IROC
Engine: LB9
Re: help me find this part!!!!
junkyard is a good bet. Other than that do a search for a part #, or someone else who has the # may chime in here. I doubt it is something you can still get dealer, but ya newver know.
do yourself a favor and use aluminum tubing from an old air conditioner or something else
steel rots out and is pointless to use, old or new all it does is put rust and crud into your engine and core and radiator, engineers who came up with the idea of using cheap steel need to be shot
if i had a nickel for every time ive seen these rot out then well you knwo what....
also find aluminum tubing in the junkyard on an old van or limo or lots of different vehicles
ive junked many over the years and had lots of this tubing heater core sized
its really common
45 bucks for a piece of cheap thin steel tubing is train robbery
insane..
if you stop and think a little you can figure out LOTS better repair methods and materials for pennies
good luck
its really common
insane..
good luck
Car: 1984 Camaro Z28 T-tops
So a small steel pipe is going to put more rust into the engine than the giant hunk of iron the engine block is made of? I agree though, $45 is pretty steep for a little metal hardline.
