new 92 rs need help
Old 07-16-2012, 12:33 PM
92rsteal's Avatar
Car: 92 rs
Engine: 3.1l v6
Transmission: auto
new 92 rs need help
hi guys i just bought a 92 rs two things i need to do are flush the rad looks like its full of rust and dirt second i need to replace the heater core i need help with getting the core out and in also i need some way to flush the coolant system with out removing it entirely any help will be appreciated thanks
Old 07-30-2012, 02:03 PM
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
Re: new 92 rs need help
easy but messy...take t-stat out and put housing back on. open drain **** on radiator, take off rad cap and stick garden hose in it while running. catch the old coolant in a bucket under the drain **** and flush till clean water comes out. There are some chemicals you can buy to stick in the radiator to aid in flushing. Once clean install new t-stat and close drain **** and fill with fresh new coolant.
Old 07-30-2012, 02:26 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
As far as the heater core..Here's a link that may help get you started. there are also tech articles in the forum. You'll have to look. Good luck!
https://www.thirdgen.org/forums/cool...placement.html
